Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Calendar view loosing URI parameter
- This topic has 2 replies, 2 voices, and was last updated 7 years ago by
- June 30, 2019 at 6:55 am #70328
zoltan.b.feher
ParticipantHi Team, I’m not able to respond to the tread directly, so I’m doing it here
Hi Team,
The calendar view is losing it’s proper URI when I change the view from month to day view or vice versa.
https://www.loom.com/share/088a02073edd44bdb9fb89ffd3392463
Please fix it!
Many thanks,
ZoltanHi,
What is your WCFM Ultimate version?
Are you using WPML?
I used WCFMu 6.1.0. Now manually updated to WCFMu 6.2.1 (I had not to receive an automatic update, I had to reactivate my license, so hopefully it will work in the future).
I use WPML.
After update to 6.2.1 the lost uri still persist.Kind regards,
Zoltan
The phenomenon - July 1, 2019 at 3:55 am #70465
zoltan.b.feher
ParticipantHi Team,
Now I have deeper trouble after update to WCFMu 6.2.1. Now I lost all links from the dashboard. https://www.loom.com/share/25227d703d8d4c05a78edfdb753af680
I need your help now!Kind regards,
Zoltan - July 3, 2019 at 1:19 pm #70795
Please go to wp-admin -> Setting -> Permalink -> update once
- The topic ‘Calendar view loosing URI parameter’ is closed to new replies.
