Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Cambiar idioma correos electrónicos
- This topic has 3 replies, 2 voices, and was last updated 5 years, 2 months ago by
- April 30, 2020 at 1:00 am #124816
michaelayala29
ParticipantHola,
Deseo cambiar el texto y cambiar el idioma a español de bienvenida de los correos que se envían a los nuevos vendedores, como se puede realizar.
You must be logged in to view attached files. - April 30, 2020 at 12:46 pm #124976
You can change the content of this email directly from frontend. Go to WCFM admin dashboard >> Memberships >> Settings (cog-wheel icon at the extreme right) >> Welcome Email and make your changes.
Let me know how it goes.
Thank You! - May 1, 2020 at 1:36 am #125206
michaelayala29
ParticipantHola,
Muchas gracias por la respuesta me funciono, pero ahora encuentro mas correos electronicos en ingles como la de las consultas tanto para el administrador, vendedor, cliente.
You must be logged in to view attached files. - May 1, 2020 at 6:10 pm #125429
KeymasterHello,
You’ll need to use Loco Translate https://wordpress.org/plugins/loco-translate/ for all translation purposes. This guide will help you getting started- https://localise.biz/wordpress/plugin/beginners
After activating the plugin go to Loco Translate >> Plugins and search for phrases in wc-frontend-manager and wc-multivendor-marketplace text doamin.
Thank You!
