Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Can a vendor add categories / Menu with categories that change per vendor
- This topic has 1 reply, 2 voices, and was last updated 6 years, 3 months ago by
- May 8, 2020 at 1:53 am #128174
development-1767
Can I make it possible for each vendor thier own specific categories?
I want to give them the opportunity to create there own category structure and create a menu with the active categories for each vendor.
For example:
you visit store A: as a customer you see at the left side a menu with the different categories: shirts – hoodies – hats
you visit stor B: as a customer you see at the left side a menu with the categories: fish – food – saladesIs this possible?
thanks in advance - May 8, 2020 at 10:35 pm #128531
Not totally. But you can achieve almost similar result using WCFM Groups & Staffs.
You can create different group with different capabilities, using WCFM Groups & Staffs. Now under each group you can specify allowed categories. So you are not letting your vendors create the attributes, but you are providing them a list from which they can pick.
Next, in Vendor Store Sidebar you can add the widget Vendor Store: Category from wp-admin >> Appearance >> Widgets. This will show the vendor categories on sidebar.WCFM also allows vendors to create new attributes, but those attributes aren’t reusable, means they will not appear while editing other products.
I hope this answers your question.
Thank You!
- The topic ‘Can a vendor add categories / Menu with categories that change per vendor’ is closed to new replies.
