Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Can i delete WCFM
- This topic has 1 reply, 2 voices, and was last updated 6 years, 7 months ago by
- March 31, 2020 at 11:03 am #114202
rt-abdullah
ParticipantHello.
I have a website that i worked really hard on it. I translated it all by wpml and i did a customized theme on it. I did something wrong and i had to restore my site using updraft plugin. It did not restore all my site and it gave a massage that saying my there were file size difference that might be corrupted. I just processed. After that my theme support did a really important customization on my theme. now i have multiple problems in my site i know it is not from the theme customazation. Some links give misconfigurations errors and some are not working such as products in the venodres store manager it take me to categories page. I am thinking to delete WCFM and re upload it again since i dont have any customers or products yet to restore all the files that might be corrupted. Is doing this fine? Will i be lossing the Customization on the theme or translations if i do that? What do you think should I do? Thank you.
- April 2, 2020 at 8:24 pm #114755
MemberWill i be lossing the Customization on the theme or translations if i do that?
– If you delete and r-install WCFM then theme customization will not hamper.
Where you have saved “translation files”? Please keep backup of those.
If you have translated using WPML then no worries.
- The topic ‘Can i delete WCFM’ is closed to new replies.
