Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Cannot see settings with WC Vendors
- This topic has 5 replies, 3 voices, and was last updated 6 years, 4 months ago by
- December 16, 2019 at 8:38 pm #97649
phillipsar
ParticipantCan you please tell me where to access the settings for WCFM Membership? I am using WC Vendors Pro. My screen (dashboard) looks nothing like the video and I have looked everywhere I can think of.
–Alana
- December 18, 2019 at 5:54 am #97847
Craig
ParticipantDo you see a “MarketPlace” Tab on your WP admin dashboard?
Clicking on that takes you to your Marketplace settings,
THEN you should see a “Membership” tab,
Click on that,
THEN you should see a “gear” top right corner,
Click on that gear and you will see all your membership settings.Hope that helps.
You must be logged in to view attached files. - December 18, 2019 at 6:58 am #97854
phillipsar
ParticipantCraig, I do not have marketplace on my dashboard. Thanks.
You must be logged in to view attached files. - December 18, 2019 at 8:19 am #97858
Craig
ParticipantHave you checked your plugins to make sure they are activated? That might be why you don’t see “marketplace”
- December 18, 2019 at 9:10 am #97865
phillipsar
ParticipantYes, Craig, it is activated. Woocommerce also reports it’s activated. I am not using WCFM Marketplace, but WC Vendors Pro, so maybe it is not really compatible with that?
- December 24, 2019 at 10:04 am #98868
MemberHI @phillipsar,
Are you able to browse WCFM Dashboard?
Don’t you have “Membership” menu under that?
thanks @Craig
- The topic ‘Cannot see settings with WC Vendors’ is closed to new replies.
