Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › can\'t activate ultimate
- This topic has 33 replies, 2 voices, and was last updated 6 years, 5 months ago by
- May 5, 2020 at 10:38 pm #127112
Marina-Martens
Participantcan’t activate ultimate
Ultimate license includes 2 green ticks
in the loco file tells me not confirmed
you can check with me also because of the menu that is not shown to me in the seller dashboard
need your email address
- May 6, 2020 at 3:28 pm #127399
To activate Ultimate license, go to wp-admin dashboard >> WCFM License, input your API License Key and API License email(both these details you will find in your order confirmation email.) and Save. This will activate your licence.
If you find any issue you can write to us here- wclovers.contact@gmail.com (mentioning the forum support link).
Thank you! - May 6, 2020 at 10:27 pm #127614
Marina-Martens
ParticipantI did everything so anyway it says here
You must be logged in to view attached files. - May 7, 2020 at 12:10 am #127685
I’m failed to understand the issue here. From your screenshot it seems the ultimate license is registered and working. So what is the issue here? And what about the loco translate snapshot? How it is relevant with the license snapshot?
Let me know!
Thank You! - May 7, 2020 at 1:16 am #127712
Marina-Martens
Participantyes i activated the license in the loco translate file for german but this is
You must be logged in to view attached files. - May 7, 2020 at 1:33 am #127714
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 2:16 am #127728
KeymasterThis reply has been marked as private. - May 7, 2020 at 2:21 am #127729
Marina-Martens
ParticipantI can not speak English
I praise myself that she still has to work saying that she is great
if you can’t do it yourself, I’ll give you access
greetest thanks - May 7, 2020 at 2:23 am #127730
Marina-Martens
ParticipantI can speak a little bit English I can show it to you
- May 7, 2020 at 3:23 am #127750
KeymasterThis reply has been marked as private. - May 7, 2020 at 3:34 am #127758
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 3:44 am #127766
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 3:47 am #127768
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 10:05 am #127857
I think I got your concern this time. You are referring to one string in Loco translate. It has nothing to do with plugin activation status.
Loco Translate shows all the translatable text, if you haven’t activated the license then you will see a warning message at the top of your wp-admin page like this- https://imgur.com/PlxWhvF
See the wording of this message, now like any other texts, I can translate the text of this message with Loco translate. That’s why it is showing under loco translate scrren.
I hope this answers your question.
Thank You! - May 7, 2020 at 6:20 pm #128049
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 6:21 pm #128052
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 6:26 pm #128053
Marina-Martens
Participantthe mail has come now
- May 7, 2020 at 6:38 pm #128056
Marina-Martens
Participanti still have the problem that the menu in the dashboard of the seller is not displayed you got access to my page via email
you can still have a look at this in my page
- May 7, 2020 at 7:09 pm #128061
Marina-Martens
Participantvielleicht geht es so besser wenn ich auf deutsch schreibe
ich habe ja immer noch das probleme das das menü im dashboard des verkäufers nicht angezeigt wird haben sie den zugang per mail bekommen zu meiner seite
können sie sich das in meiner seite noch ansehen
- May 7, 2020 at 8:25 pm #128086
KeymasterHello,
I never receive any of your email. I checked my spam folder as well. Could you please send me the access here? I will require username and password of wp-admin. Also if possible a ftp access ( hostname, username, password), as I might need to fix few css styles. When sharing do not forget to mark your reply as private.
Thank You. - May 7, 2020 at 8:35 pm #128090
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 8:37 pm #128091
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 8:57 pm #128096
KeymasterThis reply has been marked as private. - May 7, 2020 at 9:11 pm #128101
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 9:33 pm #128105
KeymasterThis reply has been marked as private. - May 7, 2020 at 9:35 pm #128106
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 10:09 pm #128114
Marina-Martens
ParticipantThis reply has been marked as private. - May 7, 2020 at 10:14 pm #128115
KeymasterThis reply has been marked as private. - May 7, 2020 at 10:39 pm #128122
Marina-Martens
ParticipantDankeschön
was war denn der Fehler
haben sie einen screenshot - May 7, 2020 at 10:51 pm #128129
Marina-Martens
Participantkann ich das problem selber lösen oder mussten sie ins ftp
will mehrere seiten anlegen - May 8, 2020 at 9:36 am #128251
Marina-Martens
ParticipantHalol
Besten Dank
was war denn n un das Probleme warum wurde das Menü beim Verkufer nun nicht angezeigt
greetings - May 8, 2020 at 9:43 am #128252
Marina-Martens
Participantverkäufer menü
- May 8, 2020 at 11:44 am #128286
KeymasterHello,
There was no issue. You just have set some wrong colors. Menu background color was set to White and the font color was also white. So all the menu was there but you can’t see them.
As this was not code editing so I did not use the FTP. I only change those colors from WCFM Dashboard (admin user) >> Settings >> Dashboard Style check here- https://imgur.com/4KEX23I
Please be careful, there are two Style menu in the setting pannel-
1. Store Style – which control color of Vendor Store Page
2. Dashboard Style (we used this) – which control dashboard elements colorThank You!
- The topic ‘can\'t activate ultimate’ is closed to new replies.
