Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Capabilities not saving
- This topic has 12 replies, 3 voices, and was last updated 7 years, 6 months ago by
Bingal.
- February 27, 2018 at 5:09 am #19515
BS
ParticipantI just updated, and noticed my inventory & attribute tab under new product are gone for my different groups, but theyre still there for admin. But I’ve checked the capabilities and they are on, but not showing on the front end
- February 27, 2018 at 6:45 am #19521
I am testing this as well.
- February 27, 2018 at 7:15 am #19522
MemberDo you have any custom coding related to this product tabs?
And those codes are depending upon WCMp capability settings anyway?
WCFM capability settings is perfect, no issues.
- February 27, 2018 at 7:25 am #19524
BS
ParticipantI don’t think so – It was working fine until I updated, problem is I updated both WCFM and WCMarketplace at the same time so am not sure which one possibly caused the issue.
- February 27, 2018 at 7:34 am #19525
MemberYeah right, that’s why I am asking you.
WC Marketplace previously has capabilities regarding this but now they have removed those.But you have written code depending upon those then it may not work.
Let me check, hope it’s under functions.php
- February 27, 2018 at 7:41 am #19526
MemberOK, I got the issue.
You have updated WCFM manually, as it’s edited, right.You have to update “core/class-wcfm-wcmarketplace.php” – then this issue will be resolved.
And be sure “core/class-wcfm-vendor-support.php” is also very very important.
- February 27, 2018 at 7:53 am #19527
BS
ParticipantI’ve just updated the plugin again, and it’s still not showing the attributes/inventory tabs
- February 27, 2018 at 8:01 am #19528
MemberYeah right as “wc-frontend-manager/core/class-wcfm-wcmarketplace.php” is still not latest one!
Kindly download WCFM directly in a separate place – https://downloads.wordpress.org/plugin/wc-frontend-manager.3.5.5.zip
Now compare “wc-frontend-manager/core/class-wcfm-wcmarketplace.php” – in your site and in that downloaded zip, you will understand what I am talking about.
Your site’s file is 966 lines but now it’s just 781 lines – significantly changed because of WCMp3.0
Is there any caching you have? Which blocking file update!
- February 27, 2018 at 8:31 am #19529
BS
ParticipantGot it thank you!
Is there anyway to change the text “Dashboard – manage your account here” without editing that file?
If not no biggieThank you so much!
- February 27, 2018 at 9:12 am #19530
MemberYes possible, using Loco Translate.
Can I help you in this?Thank You
- February 27, 2018 at 9:36 am #19531
BS
ParticipantI’ll give Loco Translate a go, If I get stuck I’ll shout.
Sorry – More importantly, for some reason it keeps overriding my wc-frontend-manager/core/class-wcfm-wcmarketplace.php file back to the file that’s only 700ish lines long, everytime I upload it, is there any reason it would be doing this? I’ve tried uploading through wordpress, through FTP etc, but it keeps reverting back which is breaking my dashboard again.
Thank you!! Sorry
- February 27, 2018 at 9:41 am #19532
MemberOpps!! That’s strange. is there any backup-restore things running?
Feel free to reach me anytime.
You may connect in Skype as well – wclovers.team@gmail.com
- February 27, 2018 at 5:08 pm #19550
Bingal
KeymasterI am closing this here!
- The topic ‘Capabilities not saving’ is closed to new replies.
