Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Capabilities Settings Page
- This topic has 1 reply, 2 voices, and was last updated 6 years, 3 months ago by
- June 13, 2019 at 5:55 am #67296
productsexport
ParticipantThere are now 3 levels
Vendors Capability
Shop Managers Capability
Shop Staffs Capability
Can you please add a button on Shop Managers and Shop Staffs to copy Vendor Capability settings? That is much easier since both Managers and staff should not have more capabilities than the Vendor itself.
Make it like this:
Vendors Capability
Shop Managers Capability [ ] Check to copy Vendors Capabilities
Shop Staffs Capability [ ] Check to copy Vendors Capabilities
Then you can click on
Shop Staffs Capabilityand modify some more if you wish. But at least you can start with similar capabilities as the Vendor.
Thank you.
You must be logged in to view attached files. - June 13, 2019 at 8:45 pm #67484
MemberOK, we will add this prohibition.
