Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › capability 'edit commissions' for managers
- This topic has 3 replies, 2 voices, and was last updated 6 years, 8 months ago by
- November 13, 2019 at 12:02 am #92063
Mcflait
ParticipantHi! i use the plugin for create managers who handle several shops… and so far so good.
But i dont know what capability i have to deactivate for hiding the commission settings from ‘add product’ page for the managers. I tried with the group capability and the general one for managers but nothing. Im lost here. :/
- November 14, 2019 at 9:09 pm #92332
Please add this code to your site –function disallow_commission_manage_for_managers() { if(wcfm_is_manager()) return false; return true; } add_filter('wcfm_is_allow_commission_manage', 'disallow_commission_manage_for_managers');Add this code to your child theme’s functions.php
Thank You - November 30, 2019 at 3:21 am #94903
Mcflait
ParticipantI tried with this filter, but sadly also disable the ‘store selector’.
so in class-wcfm-vendor-support we had:
if( !wcfm_is_vendor() && apply_filters( 'wcfm_is_allow_commission_manage', true ) && apply_filters( 'wcfm_is_allow_view_commission', true ) ) { // Associate Vendor add_action( 'end_wcfm_products_manage', array( &$this, 'wcfm_associate_vendor' ), 490 ); add_action( 'after_wcfm_products_manage_meta_save', array( &$this, 'wcfm_associate_vendor_save' ), 490, 2 );i took it out and make and if just with (!wcfm_is_vendor) (yeah, hardcoding with other changes via commits on github). If you had another workarund please let me now. Thanks!
- November 30, 2019 at 11:03 pm #95096
KeymasterChanging core files is not the recommended way to do any customization. Better remove the action and filters responsible for commission management after checking the user role –
function remove_comission_for_managers() { global $WCFMmp; if ( wcfm_is_manager() ) { remove_action( 'after_wcfm_products_manage_tabs_content', array( $WCFMmp->wcfmmp_product, 'wcfmmp_product_commission' ), 500, 4 ); remove_action( 'after_wcfm_products_manage_meta_save', array( $WCFMmp->wcfmmp_product, 'wcfmmp_product_commission_save' ), 500, 2 ); // Variation Commission remove_filter( 'wcfm_product_manage_fields_variations', array( $WCFMmp->wcfmmp_product, 'wcfmmp_commission_fields_variations' ), 500, 7 ); remove_filter( 'wcfm_variation_edit_data', array( $WCFMmp->wcfmmp_product, 'wcfmmp_commission_data_variations' ), 500, 3 ); remove_filter( 'wcfm_product_variation_data_factory', array( $WCFMmp->wcfmmp_product, 'wcfmmp_product_variation_commission_save' ), 500, 5 ); } } add_action( 'wcfm_init', 'remove_comission_for_managers', 20 );I’ll pass this to my development team and ask them to add one additional filter so that in future we can gracefully remove the ‘Commission’ tab without removing the ‘Store’ tab.
- The topic ‘capability 'edit commissions' for managers’ is closed to new replies.
