Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Capability settings does not apply to all vendors in one group
- This topic has 7 replies, 2 voices, and was last updated 6 years, 5 months ago by
Ramamurthy Krishnan.
- April 29, 2020 at 9:02 pm #124725
Henriette
ParticipantI don’t know if I’m missing something here but whenever I change something in group capabilities it does not apply to all vendors in that group.
Vendors are assigned to the same group/membership so capabilities should be the same for all member in that group right?
But on one vendor it doesn’t apply.
Also that vendor doesn’t have the option in his dashboard to hide address, email, etc.Please see attachments to see my settings and the difference between two different vendors in one group.
You must be logged in to view attached files. - April 29, 2020 at 11:32 pm #124782
Ramamurthy Krishnan
If a vendor is assigned to two different groups and in one group a particular capability is set to “ON” mode and in another group it is set to “OFF” mode then that particular capability will be “OFF” for that vendor.
Can you please check whether that one particular vendor is assigned to any other group or not?Thanks,
- April 30, 2020 at 12:04 pm #124960
Henriette
ParticipantCan you please check whether that one particular vendor is assigned to any other group or not?
Both vendors are assigned to the same group (Att. 1)
I turned off another capability (Voorwaarden = Policies) and saved. Now it’s also not applied to Vendor 1 (Att. 2)
So I made a new vendor(3) and assigned to the same group.
No SEO there in Vendor dashboard but Voorwaarden still visible. (Att. 3)So I logged out (mind you I always test vendors in incognito mode) and cleared all caches just to be sure.
After that I again logged in on vendor 1, than vendor 2, and than vendor 3.
Vendor 3 also has no option to turn off Voorwaarden. (Att.4)
But look what happens when I logged out from vendor 3 and logged in again on vendor 1.
Now vendor 1 suddenly have also no option to turn of Voorwaarden while vendor 2 and 3 stays the same when logging in again.But it’s still getting weirder.
Please have a look at follow up topic.Attachments:
You must be logged in to view attached files. - April 30, 2020 at 12:05 pm #124965
- April 30, 2020 at 5:33 pm #125047
Henriette
ParticipantHi it’s me again.
I think I know what the problem is. At least a part of it.Would you please be so kind to show me, or point me to an original and preferred English screenshot of the part in my attachment of Capabilities of Groups?
I think not all of the problems will be solved with that but there are a lot of problems coming from the Dutch translations that comes with the plugins.Thank you
You must be logged in to view attached files. - April 30, 2020 at 5:43 pm #125049
Henriette
ParticipantNever Mind.
Translation and saving problems solved.
This was a translation issue.I’ve removed and installed Ultimate and Groups & Staff again, deleted vendors and created new ones.
Now I wil try again with fresh vendors for the other problem. - April 30, 2020 at 6:59 pm #125093
Henriette
ParticipantPfff!
All seems fine now after reinstalling both plugins.
Both vendors now have the same opportunities to hide things like email, phone, address, etc. from their store front.
Also the N/A is gone on address.The problem stays however with the Dutch translations. With all due respect to the translator but these are very confusing for Dutch readers.
For instance in group Capability Control the ‘Gallery Image’ is translated (in Ultimate) as ‘Geef de hoogte van de afbeelding galerie aan.’
When you translate this Dutch sentence in English it means: ‘Indicate the height of the image gallery’.So that’s why I couldn’t find Gallery Image a few weeks ago when Sushobhan helped me with restrict Galley Images for free membership.
I hate to say this but maybe it’s better you leave the Dutch translation out of it the next time and just add a plain English and untranslated .po file
Most Dutch people and especially web developers know English very well so it shouldn’t be a problem to understand and translate themselves.Still love your plugins though.
Thank you.
- April 30, 2020 at 11:32 pm #125181
Ramamurthy Krishnan
Thanks for the appreciation.
Glad to hear that it’s working perfect for you now.
For translation issues please use “Loco Translate” plugin (https://wordpress.org/plugins/loco-translate/).Thanks,
- The topic ‘Capability settings does not apply to all vendors in one group’ is closed to new replies.
