Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Carousel of shops
- This topic has 41 replies, 3 voices, and was last updated 6 years, 6 months ago by
- February 14, 2019 at 1:14 pm #48201
vraugul1
ParticipantHello!
Tell me please, is there a carousel of shops?
So I can insert her on the site?Thank you so much!
- February 14, 2019 at 1:21 pm #48205
MemberSorry, there is nothing like this.
- February 14, 2019 at 1:27 pm #48208
vraugul1
ParticipantIs it possible to make the carousel using the endpoint?
Thank you so much!
- February 14, 2019 at 1:36 pm #48210
MemberSorry, how carousel relates to endpoint?
It’s possible to show list of vendors using shortcode.
Like this – https://ibb.co/Q92q52X
- February 14, 2019 at 1:39 pm #48212
vraugul1
ParticipantWhat’s this shortcode?
And what will the list look like when there are more than 100 stores?Thank you so much!
- February 15, 2019 at 4:45 am #48326
You may do this using such short code –
[wcfm_stores map="" sidebar="" filter="" has_orderby="" per_row="3" includes="23,15,65,5,19,25,28"]
Specify your store ids at “includes”
Well, off course this is for limited stores. Hope in home page you will not show all your vendors!
For showing all vendors you may create separate store list page.
- February 15, 2019 at 6:38 am #48359
vraugul1
ParticipantHello!
Carousel cannot be make???
Thank you so much
- February 16, 2019 at 12:52 pm #48512
Possible, you may apply Carousel JS on that store list.
- February 17, 2019 at 5:43 pm #48617
Joca
GuestI installed the plugin but it can not be seen. It’s a new version of plugin and wordpress
- February 17, 2019 at 5:45 pm #48618
Joca
GuestI apologize for the wrong topic, wipe
- February 18, 2019 at 5:36 am #48675
vraugul1
ParticipantHi.
—-“Possible, you may apply Carousel JS on that store list.”
Can you help with installing and configuring this?
Thanks a lot
- February 19, 2019 at 2:42 pm #49015
vraugul1
ParticipantHello!
Can you help me make a carousel of shops?
PleaseThanks you so much!!
- February 19, 2019 at 2:51 pm #49022
Please take help from some JavaScript developer.
It will best to contact your theme developer.
- February 19, 2019 at 3:01 pm #49025
vraugul1
ParticipantTheme developers said that it is better to contact the developers of the plugin.
Remains only programmer Java script is true?Thank you!
- February 20, 2019 at 5:45 am #49111
vraugul1
ParticipantHello!
Your programmers won’t help me?
Can be for money.Thank you very much
- February 20, 2019 at 8:22 am #49127
vraugul1
ParticipantHello!
Or I can translate the entire plugin into Russian.
And send you translations.
Can we consider such a barter?Thank you very much
- February 22, 2019 at 4:19 am #49465
Are you using any Page Builder? Then, which one!
- February 22, 2019 at 4:40 am #49466
vraugul1
ParticipantWPBakery Page Builder
Thank you so much!
- February 22, 2019 at 6:56 am #49476
We will add such a store carousel in next update – https://www.useloom.com/share/ce71e187a1754867a793ebcca8c150dd
- February 22, 2019 at 7:46 am #49479
vraugul1
ParticipantHello!
Super looking forward to!
As we finish translating the plugin, I’ll throw in this topic translations.Thank you very much
- February 23, 2019 at 6:25 am #49643
We have added this option in WCFM Marketplace 2.2.1, please update yours and take a look.
Use short code like this –
[wcfm_stores_carousel includes=""]
Specify store ids comma separated under “includes” attribute.
- February 23, 2019 at 7:20 am #49660
vraugul1
ParticipantHello!
Yeah, great, but a few questions.
Can it be made to show all the stores from a Certain group of vendors? (because they will be constantly registered and there will be a lot of them)
And the second question, how to remove this white space?Thank you very much!
You must be logged in to view attached files. - February 23, 2019 at 7:30 am #49663
“Can it be made to show all the stores from a Certain group of vendors? (because they will be constantly registered and there will be a lot of them)”
*** Yeah sure, that also possible – suppose you have 3 membership and their Ids are 41, 48, 49
Now, you want to have carousel only for membership 49, so your short code will be –
[wcfm_stores_carousel exclude_membership="41,48"]
It works same as “wcfm_stores” short code.
- February 23, 2019 at 8:06 am #49666
vraugul1
ParticipantThank you so much!
- February 23, 2019 at 8:29 am #49670
MemberYou are welcome 🙂
- February 27, 2019 at 11:55 am #50365
vraugul1
ParticipantHello!
Please tell me.
1. How to make a carousel in the entire width of the site?
2. How do I change the scroll speed?Thank you!
- February 27, 2019 at 11:55 am #50366
vraugul1
ParticipantThis reply has been marked as private. - February 27, 2019 at 12:16 pm #50373
1. Carousel width depend upon template width.
2. Override this template to change carousel speed – wc-multivendor-marketplace\views\store-lists\wcfmmp-view-store-lists-carousel.php to “child theme\wcfm\store-lists\wcfmmp-view-store-lists-carousel.php
- February 27, 2019 at 12:38 pm #50380
vraugul1
Participant1. But Revolution Slider is displayed in full width.
Please help to make a carousel is also in full width2. Now I will try
- February 27, 2019 at 1:10 pm #50387
vraugul1
Participant2.I can’t change the speed.
Thank You!
- February 27, 2019 at 1:23 pm #50391
Please help to make a carousel is also in full width*** Carousel and Slide is not same thing.
In our demo it’s full width — http://wcfmmp.wcfmdemos.com/You have to set this as per template. You may take help from theme author.
2. I can’t change the speed.
**** Override this template to change carousel speed – wc-multivendor-marketplace\views\store-lists\wcfmmp-view-store-lists-carousel.php to “child theme\wcfm\store-lists\wcfmmp-view-store-lists-carousel.php
Here is configuration – https://ibb.co/chyxrvW
- February 27, 2019 at 2:53 pm #50408
vraugul1
Participant1. All I did in full width using css
2. I did it, but the speed hasn’t changed.
Help to make it please.Thank you!
- February 27, 2019 at 3:33 pm #50416
I already give you solution to change this –
You have to change “autoplayTimeout”
- February 28, 2019 at 5:49 am #50492
vraugul1
ParticipantHello!
Yes as to change the speed I understood.
But that’s not exactly what I need.
I’d like them to swim slowly.
As you can see here:https://wordpresscarousel.com/#demo
!Carousel NAME:
Custom Link URL and Ticker Mode (Pro)Thank you!
- February 28, 2019 at 8:48 am #50505
Well, then you may define your own carousel from this template.
- February 28, 2019 at 9:02 am #50518
vraugul1
ParticipantHow do I do that?
Can you help?Thank you!
- February 28, 2019 at 9:15 am #50528
MemberWell, such things comes under paid customization.
If you are interested then may contact us here – https://wclovers.com/woocommerce-multivendor-customization/
- February 28, 2019 at 9:19 am #50529
vraugul1
ParticipantI’m interested.
I wrote.Thank you!
- February 28, 2019 at 9:30 am #50533
MemberThanks, we are checking that.
- February 28, 2019 at 10:11 am #50545
Check this – https://www.useloom.com/share/0423a050851a49f69ad5a16439060680
Is this will be fine for you?
- February 28, 2019 at 10:23 am #50551
vraugul1
ParticipantNo.
We need her to keep moving, without stopping
And stopped when you hover your mouse on the carousel.Thank you!
- February 28, 2019 at 10:58 am #50555
MemberOK, understand!
- The topic ‘Carousel of shops’ is closed to new replies.
