Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Change checkbox display on single product page
- This topic has 9 replies, 2 voices, and was last updated 6 years, 6 months ago by
- October 2, 2019 at 2:24 pm #84764
cartaclaudio
I have 2 custom check boxes, one called pre-order and the other explicit. I would like to modify their display so that it does not show when left empty. I would also like to display it in a different way which will show the universal explicit image instead of just a checkbox.
I am trying to figure out a way of doing this through functions.php, yet I have encountered a brick wall.
How can this be achieved please?
You must be logged in to view attached files. - October 11, 2019 at 9:42 am #86170
Please use this line to your site –
add_filter( 'wcfm_is_allow_custom_field_display_by_icon', '__return_false' );Add this code to your child theme’s functions.php
- October 14, 2019 at 12:29 pm #86793
cartaclaudio
ParticipantThank you so much. with this code it displays the word no instead of an icon. is it possible to not display the field at all if left unchecked?
Regards,
Claudio - October 16, 2019 at 12:06 pm #87077
add_filter( 'wcfm_custom_field_value', function( $field_value, $field_name, $product_id, $field_type ) { if( $field_type == 'checkbox' ) { if( $field_value == 'no' ) { $field_value = ''; } else { $field_value = get_post_meta( $product_id, $field_name.'_checkbox', true ); } } return $field_value; }, 50, 4 );Thank You
- October 25, 2019 at 1:33 pm #89011
cartaclaudio
I have added this code to functions.php, the function is getting in but when the field_values are no(tested by var_dump) they are still producing the checkbox post meta.
- November 5, 2019 at 7:54 pm #90868
This code will hide label if checkbox is not checked!
- November 21, 2019 at 6:20 pm #93283
cartaclaudio
I have been testing a playing around with this one, however it does not work. When the field_value is ” its returning everything as checked instead of hiding the value.
- November 23, 2019 at 11:57 am #93583
MemberWell, this code only works for checkbox type fields.
- December 15, 2019 at 4:12 pm #97545
cartaclaudio
ParticipantThanks this works great like this
add_filter( 'wcfm_custom_field_value', function( $field_value, $field_name, $product_id, $field_type ) { if( $field_type == 'checkbox' ) { if( $field_value == 'no' ) { add_filter( 'wcfm_is_allow_custom_field_display_by_icon', '__return_false' ); $field_value = ''; } else { if( $field_name == 'explicit' ) { add_filter( 'wcfm_is_allow_custom_field_display_by_icon', '__return_false' ); $field_value = '<img src="http://XXXXXXX/wp-content/themes/themify-music-child/images/explicit.png" width="64px" />'; }else { $field_value = get_post_meta( $product_id, $field_name.'_checkbox', true ); } } } return $field_value; }, 50, 4 );is there a filter I can use to hide the checkboxes name from appearing in a label?
- December 24, 2019 at 10:22 am #98875
– Sorry, don’t get this. Please show me scree shot for this.
- The topic ‘Change checkbox display on single product page’ is closed to new replies.
