Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Change product listing view to a catagorised view?
- This topic has 3 replies, 2 voices, and was last updated 5 years, 1 month ago by
Sarmistha Chakraborty.
- April 22, 2020 at 5:29 am #121577
OctopiStimuli
ParticipantIs it possible to change the products listing view from showing products to showing a category view of the vendors prodcuts.
I have enabled the subcatagory in the woocommerce settings within the flatsome theme.
How can i view it like this on the right?
https://www.loom.com/share/096a0f4558324cba8e6f45f5358fbcdbAttachments:
You must be logged in to view attached files. - April 22, 2020 at 1:29 pm #121677
We have checked your attached video.But sorry, unfortunately this requirement is not feasible for vendor store page.
- April 22, 2020 at 6:10 pm #121817
OctopiStimuli
ParticipantThanks, a possible option for the future?
How can I disable the product tab then?
Can i add a button to the about tab?
- April 22, 2020 at 8:36 pm #121894
>>At present we don’t have this in our road-map. If we have any future plan for this we will let you know.How can I disable the product tab then?
>> By-default when you browse the vendor store page the “product” tab open. So do you want to remove the product tab? If yes then which tab should be open by-default?Can i add a button to the about tab?
>> Yes you can by override the wcfmmp-view-store-about.php in your theme\wp-content\themes\<your theme>\wcfm\store
Copy the wcfmmp-view-store-about.php file from\wp-content\plugins\wc-multivendor-marketplace\views\store
