wcfm-santa
-363Day -21Hr -39Min -24Sec
wcfm-santa
Changing default vendor avatar
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Changing default vendor avatar
Viewing 3 reply threads
    • #107298
      ashley.younguk
      I would like to change the two default vendor avatars – the one in the top right corner (the profile icon) and the one in the welcome box. If I override the images in the plugin folder it reverts back when I update the plugin. Is there a way of changing this?
    • #107823
      Please know me image urls which you want to use for the purpose.
      I will give you code for this.
    • #107919
      ashley.younguk
      Hi
      So it’s this one: wp-content/plugins/wc-frontend-manager/assets/images/user.png
      and this one: wp-content/plugins/wc-frontend-manager/assets/images/avatar.png
      Thank you 🙂
      • #107921
        ashley.younguk
        I would like to change those URLs to images I upload to the wordpress media folders.
        • #107997
          add_filter('wcfm_defaut_user_avatar',function($img_url){
          	$img_url = 'http://localhost/wordpress/wp-content/uploads/2019/05/1.jpg'; //image url which you upload to the wordpress media folder
          	return $img_url;
          },20);
    • #108209
      ashley.younguk
      Amazing – worked perfectly 🙂
  • The topic ‘Changing default vendor avatar’ is closed to new replies.
