Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
01Day 20Hr 26Min 23Sec
Poila Boishakh
Check voucher code
Viewing 3 reply threads
    • #19319
      admin15
      Is there any section in WooCommerce Frontend Manager where vendor can check the voucher code?
      Woocommerce provides a shortcode to add in a page for this purpose ([woo_vou_check_code]) but it is essential for us to be visible in the vendor dashboard as well.
    • #19322
      Frankly I don’t know what this short code will do but in WCFM dashboard it’s not a factor to add a new screen or a new section.
      Now this short code can be rendered at anywhere you want.
    • #19329
      admin15
      The shortcode i provided above is for letting the vendor check the status of a voucher. It’s actualy part of PDF Vouchers which your plugin supports. Tou can see more about it here: http://wpweb.co.in/documents/woocommerce-pdf-vouchers/pdf-vouchers-setup-docs/
      So is there a way for vendor to check the vouchers through the dashboard?
    • #19335
      Thanks for the clarification.
      Actually, WCFM not yet compatible with this voucher plugin but will soon as we are already working on this.
      Currently it supports https://docs.woocommerce.com/document/woocommerce-pdf-product-vouchers/
  • The topic ‘Check voucher code’ is closed to new replies.
