Commission calculation seems wrong!
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Commission calculation seems wrong!
Viewing 4 reply threads
    • #107391
      wayneglass03
      Can you please explain how/when % commission is calculated with strip split pay, something seems off….
      I am using uk seller/buyer with the stripe UK test card, the fee should be 1.4% + 0.2£
      Item = 10£
      shipping = 6£
      total = 16
      with commission set at 10%
      Stripe fee = 0.42£
      application fee = 1£
      THIS DOES NOT ADD UP IN ANY WAY.
    • #107444
      wayneglass03
      I now see what i overlooked, but can you tell me how to include shipping in the calculation, i dont see an option anywhere.
    • #107831
      You may add this line to apply commission rule on shipping cost –
      add_filter( 'wcfmmp_is_allow_commission_on_shipping', '__return_true' );
      Also may add this line to apply on Tax cost –
      add_filter( 'wcfmmp_is_allow_commission_on_tax', '__return_true' );
    • #108202
      wayneglass03
      I used this with the snippets plugin, stripe shows commission correctly. Thank you very much. Maybe adding a toggle for this could be a good feature to consider.
      Can you tell me if there is a way to edit the colour of the menu toggle and notification bubbles in the dashboard?
    • #108679
      Please setup dashboard elements colors from WCFM Admin Setting -> Dashboard Style – https://ibb.co/LzD2pkn
  • The topic ‘Commission calculation seems wrong!’ is closed to new replies.
