Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Commission is not picked correctly
- This topic has 5 replies, 2 voices, and was last updated 6 years, 11 months ago by
- August 23, 2018 at 11:16 am #29337
kasaga311
We have setup Commission per vendor in our app.
The WCFM – Ultimate/Marketplace doesn’t pickup that value and instead shows ‘By Global Rule’ under Store settings.
Even if we change the value to anything else other than that, it doesn’t pickup whatever we set per vendor using the Dashboard -> Users -> Commission field.
The Commission amount showed in Order is the exact amount calculated per the value set using Dashboard.
Kindly let us know what is it that we need to do in this case.
–Kasaga - August 25, 2018 at 6:17 am #29653
kasaga311
ParticipantThis reply has been marked as private. - August 28, 2018 at 3:38 am #29901
Kindly know me, which multi-vendor plugin you are using?
As I remember, you have WC Marketplace, right?
- September 3, 2018 at 6:28 am #30609
I think this is the same issue –
“the Earnings should be ‘Gross – (GST etc)’” – you may manage this from commission settings.
Disable “Tax goes to vendor?” option from WCFM Admin Setting -> Commission setting
Please check this for more info – https://wclovers.com/knowledgebase/wcfm-marketplace-commission/
- September 3, 2018 at 6:36 am #30613
kasaga311
This works fine now.
–Kasaga - September 3, 2018 at 7:16 am #30625
MemberGreat, thanks for confirming 🙂
- The topic ‘Commission is not picked correctly’ is closed to new replies.
