Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Commission setting – 0% or £0?
- This topic has 5 replies, 3 voices, and was last updated 6 years, 4 months ago by
kaloomee.
- August 12, 2019 at 1:28 pm #76264
kaloomee
ParticipantIs it Possible to set commission to 0% or £0?
If I try to set this in product category commission I get error – Value must be greater than or equal to 0.1
% or fixed
- August 12, 2019 at 6:08 pm #76295
macnomo
Have you tried to leave it blank?
If enter “0”, without percentage sign?
or try Vendor=100% instead of Admin=0%Hope it helps
- August 13, 2019 at 5:45 am #76356
Do not insert sign in either case. As you have set commission mode – percentage or fixed then it will auto calculate.
- August 13, 2019 at 9:28 am #76407
kaloomee
ParticipantIf I try to set this in ‘product category’ commission I get error – Value must be greater than or equal to 0.1
No sin added, just 0
products > categories > Select category > edit >
Commission Mode = percent
Commission Percent(%) = 0Screenshot attached
You must be logged in to view attached files. - August 20, 2019 at 5:06 am #77388
Well, if you want to set “0” commission then leave that box empty.
- August 20, 2019 at 8:41 am #77471
kaloomee
ParticipantAha – Thank you
- The topic ‘Commission setting – 0% or £0?’ is closed to new replies.
