Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Commission specific rules
- This topic has 3 replies, 2 voices, and was last updated 6 years, 11 months ago by
- September 10, 2018 at 9:06 am #31260
Vinz
ParticipantHi WC LOVERS,
I have a request about your commission system rules.
In the global rules settings, you give the possibility to choose to whom is going the commission (admin or vendor) which is very useful! But, in the product specific setting, we can’t choose this setting.So, is it possible to set it here too ?
Thanks !
Vincent
- September 11, 2018 at 10:23 am #31325
“In the global rules settings, you give the possibility to choose to whom is going the commission (admin or vendor) ”
This rule is applicable for other commission setting as well – vendor and product
- September 11, 2018 at 10:55 am #31328
Vinz
Thanks for your answer !
So, if I understand you, for example, in the global rules settings, I set the commission is going to the Admin. In the product commission setting I would like to set a specific percentage for a specific product; this new commission rate will go to the admin too ? Because in the products commission settings, I have no field to choose to whom is going the commission …Thanks
- September 11, 2018 at 4:47 pm #31365
“So, if I understand you, for example, in the global rules settings, I set the commission is going to the Admin. In the product commission setting I would like to set a specific percentage for a specific product; this new commission rate will go to the admin too ? ”
– Yeah right, commission mode always works as per Global Rule. If you have set this “Admin” then all commission whether it’s set at vendor level or product level will go to Admin.
- The topic ‘Commission specific rules’ is closed to new replies.
