Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Compatibility between WCFM and WP Stateless (for google cloud)
- This topic has 1 reply, 2 voices, and was last updated 6 years, 9 months ago by
- July 2, 2019 at 8:27 am #70647
aghorbany
ParticipantHello
I like to know is WCFM-ULTIMATE compatible with WP-Stateless plugin?
In your plugin’s description, you mentioned that they are compatible but there are some problems that I will explain and also add some photos.
In fact, everything is working just fine when WP-Stateless is disabled and can add photos and save them with no problem.
Also, when I activate WP-Stateless, it’s working with every WP and it’s plugins nicely with no problem at all except with WCFM.
When I want to add new product and want to add photos as product photo or product gallery or in the when I add photo in the product description, I’m able to add photos.
But when I save (Submit) the product, after refreshing the page it shows me nothing (just default photo) in product photo and gallery, however, in the product description, photos will save with no problem.
When I add products directly from Woocomerce in WordPress dashboard there is not such a problem!
I’m just wondering for some months that what is the problem and still did not find any solution for that.
It’s very very important to use google cloud when using your plugin.Attachments:
You must be logged in to view attached files. - July 4, 2019 at 8:31 am #70991
Do you have set any custom “Bucket Folder” ? – https://ibb.co/3h0xT5T
If yes, then please remove that and check once.
WCFM not yet support this bucket folder. We will add this support in next update.
