Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Coupon on product page
- This topic has 5 replies, 2 voices, and was last updated 7 years ago by
- June 13, 2019 at 7:13 pm #67440
kaloomee
Is it possible to show a coupon on the product page
Ie – product 1 has a coupon for a 10% discount
I am aware that I can show store coupons in store page and can add store coupons widget on sproduct page but my product pages have no sidebar to place a widget
Theme I use has capability for
CUSTOM CODE AREAS
After Button Area
This code zone is visible on all products after Add to cart ButtonBefore Content
This code zone is visible on all products before ContentBefore footer
This code zone is visible on all products Before FooterIn floating panel
Code zone inside product loopIs there a code to display a coupon on the product page only for product that has coupons please
No coupon = no display - June 14, 2019 at 6:24 am #67561
There is a widget – “Vendor Store: Coupons” – https://ibb.co/71kTNr5
You may add this under product page sidebar and it will show that vendor’s coupons.
- June 14, 2019 at 11:10 am #67604
kaloomee
ParticipantThank you for reply
But…. As explained – My product page display does not have a sidebar/widget areaI was hoping that there would be a solution to show the coupon in the product display area – ie above price.
Regards
Iain - June 15, 2019 at 4:35 pm #67854
Then what will require? Short code for this!
- June 15, 2019 at 4:59 pm #67871
kaloomee
ParticipantHI,
If possible by shortcode then that would be great
May also be possible with code as my Theme (Rehub > Revendor) I use has capability for
CUSTOM CODE AREAS
After Button Area –
This code zone is visible on all products after Add to cart ButtonBefore Content –
Regards
Kaloomee - June 18, 2019 at 11:23 am #68297
You may check this file to get code for this – wp-content\plugins\wc-multivendor-marketplace\includes\store-widgets\class-wcfmmp-widget-store-coupons.php
- The topic ‘Coupon on product page’ is closed to new replies.
