Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Coupons and Commission
- This topic has 14 replies, 2 voices, and was last updated 6 years, 7 months ago by
Jose.
- March 9, 2019 at 4:19 pm #51731
Jose
ParticipantI would like to improve the relationship between the discount coupons and the administration commission.
An example:
I have a fixed and global commission to all stores of 15%.
I wish for black friday to make a discount coupon for all stores with a 15% discount.
To not assume the cost of this discount coupon, I change that day the commission to 0%, and I warn stores about it, so they do not assume that cost either.
Everything looks very good, but the problem is that if any customer buys that day without a discount coupon, the store will be the only one benefited, since they can sell their products at 100% of the price and without commission.
Will it be possible to make some adjustment to identify the purchase without coupon and in that case maintain the 15% commission?
Thank you,
- March 10, 2019 at 6:29 am #51806
“To not assume the cost of this discount coupon, I change that day the commission to 0%, and I warn stores about it, so they do not assume that cost either.”
– Why this? There is a setting option at Commission setting panel -> Commission after deduct discounts?
Now, if you disable this then vendor commission will calculate on product’s actual price, coupon discount will not be considered.
Hope this will resolve your purpose, and no require to change commission percent.
- March 10, 2019 at 3:04 pm #51845
Jose
Your answer was very clear and I thank you for that.
The only problem I see is the information that is displayed for the seller in the mail and in the orders when a customer (the day of black friday) uses the OFF coupon. (CASE 2)
Apparently he is not showing the reduced commission. Instead the administrator shows it correctly (admin view)
Regards,
You must be logged in to view attached files. - March 10, 2019 at 3:04 pm #51850
- March 10, 2019 at 3:17 pm #51853
Jose
I forgot to ask something related to the generation of the coupon. Is it possible to add the from and to? Instead of Coupon expiry date? Since it currently requires a manual enablement. The programming will always be better.
It is inevitable that I wish there were programming here to disable the Commission after deduct discounts (Maybe only for Admin like Black Friday Purpose).Regards,
- March 10, 2019 at 3:51 pm #51858
Jose
ParticipantUpdate !
It’s not necessary my request about programing disable the Commission after deduct discounts, I made a test with this case and work fine.
Just need it the from and to !
- March 11, 2019 at 3:27 am #51915
Possibly you have setup commission “For Admin”
Please tweak this to “As Vendor” and take a look.
- March 11, 2019 at 11:52 am #52034
Jose
ParticipantWell, I use commission for admin, because is more clear to me and vendors. Commission is like a fee.
But, can you please compare screen order view (admin vs vendor) because I say that only admin view correctly the commission fee.
https://wclovers.com/forums/topic/coupons-and-commission/#post-51845Case 2 was:
Product price: 1000
coupon 15%: 150Commission fee: 50 (because was the difference between 200-150) I have global commission of 20%
To vendor: 800
The same issue happend with email to vendor case 2
https://wclovers.com/forums/topic/coupons-and-commission/#post-51850Thank you
- March 12, 2019 at 3:58 am #52175
OK, no issues. Then it’s showing right to vendors.
Total product cost 1000 and vendor commission 800
Now, rest is for Admin Fee – 200
May be Admin allowed coupon discount so he is getting 150, instead 200. But vendor’s commission does not consider that, so he is seeing 200.
- March 12, 2019 at 12:40 pm #52273
Jose
Yes, admin allowed coupon for 15% (150) so he is getting just 50 !!
Ok, I will talk only about Case 2:
In this case I do not agree with the use of the commission concept, nor how the numbers are shown.
In my case the commission (a charge to discount) is for the Administrator. Therefore, the balance is a value to be charged by the seller with the withdrawal request. I understand how complex it is to modify depending on the case if you choose commission for the administrator or the seller.
For this I can hide the commission in the seller’s view from the list of orders.
More important, it seems to me that the detail of the order is shown differently. The administrator’s view seems much closer to reality. The only thing that would be missing is to show the gross price.
On the other hand, in the seller’s view, the gross price is shown, but the use of a coupon is not shown and it is not clear then why the invoice should be made. (remember that in my country is done in a different way to what the bill offers within this system)
I’m imagining a seller’s query saying: I do not understand.Regards,
You must be logged in to view attached files. - March 12, 2019 at 4:37 pm #52308
wp-content\plugins\wc-frontend-manager\views\orders\wcfm-view-orders-details.php
– This is order details template, you may override this at child theme\wcfm\orders and may tweak as per your requirement.
- March 12, 2019 at 5:18 pm #52319
Jose
Ok, I will try !!
But the same happend with the order email to vendor, show the same and I’m not sure if I can make the same.
Regards,
- March 12, 2019 at 11:02 pm #52346
Jose
I was trying to changes something in the file that you tell me, but it was frustrating.
I have a first problem… How vendor know for how much he need to make a invoice (manual invoice in paper)
Her product cost 1000 and he have 20% admin commission.
But the admin made a 15 off this day. (disable Commission after deduct discounts)So, for me the customer see:
1000 – 150 (coupon)
Total = 850 to paidWe need that vendor see the same, because he need to made a invoice for 850
But, after he know that have just only 5% of commission, because 20%-15% = 5%
So in her order detail will be better that he see just 50 for commission.
Then 850 – 50 = 800 her gain
After that, he make a withdrwal request for 800
And I make a invoice for 50 to vendor.
So, how can I try to make vendor order view idem admin order view ?
I hope you undertand my request, I saw wc order detail and made the same, don’t understand why never show the initial cost 1000
Regards,
- March 19, 2019 at 2:34 pm #53512
Jose
I’m come back, because I found another problem or insufficient information for the vendor.
I made a test with a coupon discount of 10% from the vendor in this case.
So the issues are:
1.- Vendor don’t know what is the discount that see
Admin know that is a coupon (and see what coupon)
2.- Both, the admin and the vendor know how much was the purchase.
But vendor need a calculator to know it.
3.- Last one. We don’t use tax just the final for products and shipping.
Why vendor view show it ?I know that admin view are exact to Woocommerce show in orders, and I undertand that you need to make a new view for every vendor.
The same happend with the detail of product price, Woocommerce don’t show the gross value, just show the price minus discout and show in grey the discount value at rigth of product item.But I would like, if you can help me, to have the same order items like admin in the vendor order view. For me have all info that need it.
I know that all code are inside of <table class=”wc-order-totals”> but I can’t to show the same info in both order views (admin and vendor).
I hope you can.
Best regards,
You must be logged in to view attached files. - March 22, 2019 at 12:50 pm #53997
Jose
I have good news !
Resolved !, I made a lot of test changing the code and was successfull.
Regards,
- The topic ‘Coupons and Commission’ is closed to new replies.
