Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Coupons Vendor Vs Admin
- This topic has 7 replies, 4 voices, and was last updated 6 years, 5 months ago by
Jose.
- February 9, 2019 at 9:15 am #47373
mitchellstringer
ParticipantI would like to understand Coupons better.
If set a coupon as Admin, this is site-wide, if a vendor sets a coupon its only for the vendor. This is good.
However if i set a coupon as admin, i would like the full amount of commission to go to the vendor (admin pays for coupon discount)
But if the vendor sets a coupon I would like the vendor to pay for the coupon discount
is this possible? if so I don’t know how to configure the settings
- February 9, 2019 at 5:20 pm #47452
Well, hope you noticed there is a setting option for this. Whether commission will consider coupon discount or not! https://ibb.co/265Y9SM
But this works for all discounts, not consider whether it’s Admin coupon or Vendor coupon.
- February 9, 2019 at 5:21 pm #47453
MemberWell, there is a sort out of this,
As Admin you always create “cart discount” coupon.
And Vendor coupons are by default product coupon.
- March 21, 2019 at 2:06 pm #53836
Lim Kok Heng
Is there any way to achieve the consideration whether it’s Admin coupon or Vendor coupon and pay commission accordingly? I need to have this feature on my site too.
- March 22, 2019 at 9:13 am #53963
Please keep this setting enable from WCFM Admin Setting -> Commission Setting – https://ibb.co/BBGXR3m
Hence all coupons will be considered before commission calculation!
- March 22, 2019 at 3:19 pm #54025
Jose
I want to add me to the request, because it’s true.
It’s not the same if vendor made a coupon or admin.
Admin need to made coupons like black friday, but it needs not to affect the vendor.
I made test with your advice about commission setting and we have diferent result, but bad for vendor when coupons come from admin.
Normal Example: (80% commission to vendor)
Product: $ 15000
Shipping: $ 3800
Total: $ 18800Withdrawal to request: 15800
Coupon example: (15% coupon from admin)(80% commission to vendor)
Product: $ 15000
Shipping: $ 3800
Coupon Discount: – $ 2250
Total: $ 16550Withdrawal to request: 14000
You can see that we will need different setting to make the same result for vendor.
For simple sells we can use your setting (commission after discount), but for admin coupon whe need to change to commission before discount.Regards,
- March 23, 2019 at 1:19 pm #54211
– We will create this option to distinguish Admin and Vendor coupon for calculating commission.
- March 23, 2019 at 1:28 pm #54214
Jose
It’s a really good news !!
Sorry, at the same moment I send you a email with this topic, but I don’t saw this answer.
Regards,
- The topic ‘Coupons Vendor Vs Admin’ is closed to new replies.
