Multi Vendor Marketplace Plugin | WCFM Marketplace › Forums › WCFM – Ultimate › coustom fields filterable
- This topic has 5 replies, 3 voices, and was last updated 7 years ago by
Bingal.
- March 19, 2018 at 2:51 pm #20591
Aree
GuestGood day, is it possible to filter the coustom fields I had already talked to your colleague bingal about it but hey you have closed the thread for that reason I’ve opened a new one. I would just like to filter the coustom fields I hope you can give me some tips or maybe help me.
See Picture:
http://www.sellbike.de/help/filter.jpgThank you very much helped me a lot already.
Super Service!
- March 19, 2018 at 7:43 pm #20597
Bingal
I am really sorry for the inconveniences, I didn’t close your last thread.
But I know this happen sometime, may be a small bug in great BBPress 🙂Anyway, as I remember you asked me about this but we didn’t talk on this.
Are you looking for search filter using these fields?
If so, then absolutely possible. When you are creating a custom field you have to set a “name” for the field and that has been used as “meta_key” for storing that field in database.Now, you may just use this “meta_key” for any search filter.
Please rectify me, if I am interpret your query in some other way!
- March 21, 2018 at 11:06 am #20666
Aree
GuestThis reply has been marked as private. - March 23, 2018 at 4:07 am #20754
Certainly picture is blank!
- March 26, 2018 at 9:00 am #20891
Aree
GuestThis reply has been marked as private. - March 31, 2018 at 6:56 am #21117
Bingal
As I told you, custom fields are stored in meta field, so you may use this for filter.
But how, it’s depending upon your filter plugin. I have setup this once using FacetWP and works perfectly, as I remember.
- The topic ‘coustom fields filterable’ is closed to new replies.
