wcfm-santa
-365Day -5Hr -1Min -47Sec
wcfm-santa
Create hidden supplier store, for other shops to sell their product
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Marketplace (WooCommerce Multivendor Marketplace) Create hidden supplier store, for other shops to sell their product
Viewing 1 reply thread
    • #121147
      Dana
      I have created a membership and group with permissions for a vendor type “Supplier”. I also created a group and membership for local seller store that can use the Product Multivendor option. Ideally these sellers will be able to build their local stores with products available from the “Suppliers”. However, I don’t want purchases directly from the “Supplier” itself, so I don’t want products to display if they are only on the “Supplier” store. I basically don’t want products to to show if they are only on the Supplier site. I only want them to display if they appear on the local seller sites. Is there a way to control the visibility of what appears on the shop main page?
      Additionally, how can I control the display of main shop page? Is there documentation on that I’ve missed?
    • #122027
      Dana
      Thought I’d check-in on this, any ideas would be appreciated.
