CSV Import settings
Viewing 1 reply thread
    • #79618
      Stefan Sittmann
      Hey Folks, I need to understand some things about csv Importer on the vendor page…
      1: Is there a way to import the categories? If so… how?
      2: What if I have just 3 Master-Categories for products where all imported products have to be sorted in?
      (for example I have just the category “FOOD” but vendor imports category “vegetables”… how can I change it?)
      3: If needed… Can you recommend a plugin which works well with multi vendor product imports?
      Thanks in advance
    • #79931
      Product Import off course support category import and association with product.
      Please check this CSV creation documentation – https://docs.woocommerce.com/document/product-csv-importer-exporter/
  • The topic ‘CSV Import settings’ is closed to new replies.
