Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › custom add product page
- This topic has 14 replies, 3 voices, and was last updated 7 years ago by
- July 17, 2018 at 9:08 am #26444
roberta
I have woocommerce membership and I need that the vendor could add a different price for each membership. I use your front end manager., but doesn`t show the tab for the membership price. how can I customize the add product page?
Thank you so much - July 17, 2018 at 12:39 pm #26445
You may override WCfM product manager templates under your theme folder and may edit those as pr your requirement.
Check at “wc-frontend-manager/views/products-manager” -> You may override this at “yourtheme/wcfm/products-manager/”
You may add additional fields over there.
For save use this hook – do_action( ‘after_wcfm_products_manage_meta_save’, $new_product_id, $wcfm_products_manage_form_data );Thank You
- July 17, 2018 at 1:18 pm #26460
roberta
Guestis there any documentation? I don`t know how can add this
- July 17, 2018 at 1:37 pm #26463
roberta
GuestHi try to use woocommerce-role-based-price that is compatible with your plugin, but crash
- July 17, 2018 at 3:25 pm #26474
Possibly it’s conflicting with some other plugin. It’s not updated for last 3 months, so I have doubt is this properly working with latest WC or not!
Between, you may add any additional field for Products using WCfM Custom field as well. Check this – https://wclovers.com/knowledgebase/wcfm-custom-fields/
- July 18, 2018 at 9:25 am #26504
roberta
GuestI update with last version and I see that miss in Role Based Price integration the button to update the price. If you don
t add this button the price for each role doesn
t work. how can I fix this ? - July 18, 2018 at 7:32 pm #26543
No, separate button required here.
Just set price and save the product, it will update prices automatically.Thank You
- July 19, 2018 at 9:40 am #26580
roberta
GuestBelieve me, I try but don`t works!!!
- July 19, 2018 at 9:41 am #26581
roberta
GuestI need to go in the wp-admin part, go into edit product page, click on Save price button and then I see the correct price for each role.
using the frontend manager don`t work
- July 19, 2018 at 10:12 am #26588
I am testing this once again!
- July 20, 2018 at 3:52 am #26650
Yeah right, there is an additional “Enable Role Based Pricing” option, which is not updating from WCfM product manager.
Don’t worry, we will resolve this in next update.
- July 20, 2018 at 8:35 am #26657
roberta
GuestThank you so much!
how many times you think to need for the next update? - July 20, 2018 at 10:40 am #26658
Next update will there in mid of next week.
- July 30, 2018 at 8:22 pm #27277
Sean Mac
ParticipantI too was looking for a solution to edit the add product page and I found this thread. For anyone reading this, this solution also works if you’re using WCFM Ultimate. Just change the folder path to yourtheme/wcfmu/products-manager.
Hope this helps!
- July 31, 2018 at 6:22 am #27300
This is not right path – “yourtheme/wcfmu/products-manager”
It was working for old WCfM Ultimate versions.
If you are using WCfM Ultimate 4.2+ then path should be – “yourtheme/wcfm/products-manager”
Between, “User role price” issue resolved.
- The topic ‘custom add product page’ is closed to new replies.
