Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Custom Field
- This topic has 5 replies, 2 voices, and was last updated 7 years, 4 months ago by
- June 3, 2019 at 5:37 pm #65759
vnatius
ParticipantHi, thanks for the good work so far. I wrote to you guys regarding my custom fields not showing after adding options. I have a farm marketplace for an agricultural product and these products range at different varieties of measurements (Unit of measurement), I got an email stating that this addon is best for this (https://woocommerce.com/products/measurement-price-calculator/), my major question is this; Can this addon be compatible with the WCFM? I only tired of the booking and auction and they work well. Is this addon good for this option? The next challenge is this, I am trying to specify the kind of product (Organic or Inorganic) and the custom field doesn’t show this. What other way can i do this please?
- June 4, 2019 at 9:07 am #65832
https://woocommerce.com/products/measurement-price-calculator/ – yeah sure, WCFM compatible with this addon.
Here is all compatible plugins’ list – https://wclovers.com/wcfm-compatible-plugins/
Kindly show me your custom field setting screenshot.
- June 6, 2019 at 7:23 am #66168
- June 6, 2019 at 7:31 pm #66275
I don’t get this.
When WCFM directly compatible with this addon then why are you trying to add using custom filed.
Well, this plugin’s setup is very complex. It’s not possible to setup using WCFM Custom fields.
- June 7, 2019 at 7:00 am #66363
vnatius
ParticipantI don’t understand what you mean by this “When WCFM directly compatible with this addon then why are you trying to add using custom filed”. please can you explain
- June 10, 2019 at 9:09 pm #66853
https://woocommerce.com/products/measurement-price-calculator/ – WCFM compatible with this addon.
https://wclovers.com/wp-content/uploads/2019/06/Screen-Shot-2019-06-06-at-8.21.09-AM.png – then why you are trying to create WCFM Custom field for this ?
- The topic ‘Custom Field’ is closed to new replies.
