wcfm-santa
The New Year has begun! Avail upto 25% OFF on WCFM Addons.
01Day 07Hrs 45Min 35Sec
Custom field is not working of frontend manager dashboard
Multi Vendor Marketplace Plugin | WCFM Marketplace Forums WCFM Custom field is not working of frontend manager dashboard
Viewing 1 reply thread
    • #11670
      Sarika Patel
      i added two fields in my frontend manager dashboard but these are not working and not displaying product page
    • #11671
      WCfM Forum
      Hi Sarika,
      I just want to clarify one thing to you.
      WCfM custom fields are for capturing additional data when you are creating a Product from Front-end.
      But, for display those or how to use those in Single Product page is not part of WCfM.
      If you are adding custom fields for a third party plugin then it will show those fields for you. But you have created your own fields then you have to use those using your code.
      It’s very simple also, just over ride WC single-product.php in your child theme and display those Fields where you want.
      If you have any further queries feel free to share with us.
  • The topic ‘Custom field is not working of frontend manager dashboard’ is closed to new replies.
