Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Custom Plan Page
- This topic has 18 replies, 6 voices, and was last updated 5 years, 5 months ago by
- May 26, 2019 at 6:33 am #63821
productsexport
ParticipantDo you have instructions on how to setup up the “Custom Plan Page” and the vendor registration flow?
- May 28, 2019 at 7:19 pm #64162
You may create custom plan using any Pricing Table plugin for wordpress. e.g. https://wordpress.org/plugins/pricing-table-by-supsystic/
You just have to use membership subscription button short code for creating buttons for that table – https://ibb.co/NNFNxxK
And set that custom plan page here – https://ibb.co/fS4FST0
Registration flow will be same.
- May 30, 2019 at 11:36 am #64975
productsexport
ParticipantThank you for replying.
The plug-in you recommended is very complicated to setup and slow. I used another much easier plugin called
“WordPress Responsive CSS3 Pricing Tables” https://wordpress.org/plugins/wrc-pricing-tables/In setting up the button and tables
Button Text:
Button Link:I setup these two fields as follows:
Button Text: Katılmak (Join)
Button Link: [wcfmvm_subscribe id=”207″]When I save the column, the plugin changes the button link to:
Button Link: http://[wcfmvm_subscribe%20id=207]Of course that does not work properly on the Pricing page.
What should I do?
You must be logged in to view attached files. - May 31, 2019 at 8:25 pm #65285
You have to use this short code – [wcfmvm_subscribe id=”207″]
http://[wcfmvm_subscribe%20id=207] – this has no meaning.
- June 1, 2019 at 12:08 am #65349
productsexport
ParticipantI use [wcfmvm_subscribe id=”207″] but the plugin changes it into a link http://[wcfmvm_subscribe%20id=207] when I save the page.
- June 1, 2019 at 9:25 am #65402
MemberUmm … this possible that Pricing table only support “URL” for buttons.
Please confirm this form that plugin’s author.
But as I know most of the Pricing Table plugin support short code for buttons, has option for this.
- June 17, 2019 at 8:15 pm #68141
- June 18, 2019 at 1:57 pm #68364
productsexport
ParticipantYes, it seems that Pricing table plugin only support “URL” for buttons.
- June 19, 2019 at 9:31 pm #68676
bsbmcb
ParticipantAlmost every pricing table I have found don’t use shortcode for botton, just link.
Is there some possible to use link beside shortcode for tables botton?
- June 21, 2019 at 4:20 pm #68892
– It’s not right, all Pricing table support short code for buttons. But most of them have this option in premium version.
few even support custom code option!
- July 21, 2019 at 9:11 pm #73344
r_guayaquil
I am having the same issue. I followed the steps you mentioned above but i cant get the button to work properly in the Custom Plan Page.
I am using the flatsome theme which already comes with the price table feature.
- July 24, 2019 at 3:59 am #73632
– What are the options it’s support for pricing table button?
- July 30, 2019 at 6:32 pm #74560
r_guayaquil
It looks like only support URL.
I had to create the membership page thet plugin gives as default, and then hide the page and just copy the links of th subscribe buttons and paste them in my custom plan page buttons.
You must be logged in to view attached files. - August 3, 2019 at 6:15 am #74938
MemberOK, we will add “Subscribe Button” URL support in next update.
- August 3, 2019 at 8:31 pm #75081
r_guayaquil
ParticipantThanks!
- August 5, 2019 at 12:34 pm #75309
MemberYou are welcome 🙂
- October 1, 2019 at 11:55 pm #84700
gettingweduk
ParticipantHi there,
Has the update been done for the urls to be available for the pricing tables please?
- January 18, 2020 at 3:22 pm #102590
Michel Carriere
ParticipantHi.
I create a custom plan page and indicate it in the field “custom plan page” field. But when a new vendor create his account he will see the classic plan page. On the other hand, my custom plan page is correctly used in the case of a vendor update his plan. Please see screen shots.Attachments:
You must be logged in to view attached files. - February 7, 2020 at 12:47 pm #106065
– How vendors are creating their account? How they are getting registration page URL? Is this from WC My Account “Become a Vendor” link?
