Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Custom product field not working
- This topic has 7 replies, 2 voices, and was last updated 6 years, 7 months ago by
- May 18, 2019 at 8:42 am #62759
- May 18, 2019 at 4:18 pm #62831
Please update WCFM Ultimate 6.1.1, this will resolve for you.
- May 18, 2019 at 4:25 pm #62835
wwsAdmin
ParticipantHI,
Even after update its same, green check is coming
<span class="wcfm_custom_field_display_value"><span class="wcfmfa fa-check-circle" style="color:#20c997"></span></span>Kindly look into it
thanks
- May 19, 2019 at 11:43 am #62903
Do you have updated WCFM Ultimate to 6.1.1 ?
If there has any cache for the site, then please refresh those once.
If still not resolve, then add this to your functions.php –
add_filter( 'wcfm_is_allow_custom_field_display_by_icon', '__return_false' );Thank You
- May 19, 2019 at 11:44 am #62904
MemberWell, just to mention. We have added this “icon” display only for “checkbox” type fields. Yes => Green Tick, No => Red Cross
- May 19, 2019 at 11:53 am #62905
wwsAdmin
ParticipantHI,
Let me clear site cache and everything?
one more thing i have copied wcfm in my theme: products-manager and settings folder. do i need to change it ?
As you can see i have selected <select> option not checkbox.Thanks
- May 19, 2019 at 12:11 pm #62907
wwsAdmin
There was cache clearing it helped.Thanks ♥
- May 20, 2019 at 4:22 am #62971
MemberGreat … thanks for the update 🙂
- The topic ‘Custom product field not working’ is closed to new replies.
