00Day 08Hr 38Min 25Sec
Custom Settings Fields
Viewing 4 reply threads
    • #106672
      ashley.younguk
      I would like to add a custom field under the store settings just under the store email field called ‘Store Type’, its just a simple plain text field (not text area). I would then like to display this using the shortcode [wcfm_store_info id=”” data=”store_type”].
      Can you help please?
    • #106837
      add_filter('wcfm_marketplace_settings_fields_general','wcfm_marketplace_add_custom_field_settings_fields_general',10,2);
      function wcfm_marketplace_add_custom_field_settings_fields_general($fields, $user_id) {
      	$vendor_data = get_user_meta( $user_id, 'wcfmmp_profile_settings', true );
      	$store_type          = isset( $vendor_data['v_store_type'] ) ? esc_attr( $vendor_data['v_store_type'] ) : '';
      	if(isset($fields['store_name'])) {
      	$fields = array_slice($fields, 0, 3, true) +
      	array("v_store_type" => array('label' => __('Store Type', 'wc-frontend-manager') , 'type' => 'text', 'class' => 'wcfm-text wcfm_ele wcfm_name_input', 'label_class' => 'wcfm_title wcfm_ele', 'value' => $store_type )) +
      																	array_slice($fields, 3, count($fields) - 3, true) ;
      	return $fields;
      add_action( 'wcfm_wcfmmp_settings_update','fn_wcfm_vendor_settings_storetype_update', 30, 2);
      add_action( 'wcfm_vendor_settings_update','fn_wcfm_vendor_settings_storetype_update', 30, 2);
      function fn_wcfm_vendor_settings_storetype_update($user_id, $wcfm_settings_form ){
      	$wcfm_settings_form_data_new = array();
      	parse_str($_POST['wcfm_settings_form'], $wcfm_settings_form_data_new);
      	$wcfm_settings_form_data_storetype = array();
      	if(isset($wcfm_settings_form_data_new['v_store_type']) && !empty($wcfm_settings_form_data_new['v_store_type'])) {
      		$wcfm_settings_form_data_storetype['v_store_type'] = $wcfm_settings_form_data_new['v_store_type'];
      	$wcfm_settings_form = array_merge( $wcfm_settings_form, $wcfm_settings_form_data_storetype );
      	update_user_meta( $user_id, 'wcfmmp_profile_settings', $wcfm_settings_form );
      add_filter('wcfmmp_additional_store_info','vendor_store_type_wcfmmp_additional_store_info',10,3);
      function vendor_store_type_wcfmmp_additional_store_info($data_value, $data_info, $store_id) {
      	$vendor_data = get_user_meta( $store_id, 'wcfmmp_profile_settings', true );
      	if($data_info == 'store_type') {
      		$data_value = '<p>'.$store_type.'</p>';
      	return $data_value;
    • #106869
      ashley.younguk
      @Sarmistha Chakraborty
      Thank you – this has added the field – now how can I display it with the shortcode [wcfm_store_info id=”” data=”store_type”]?
      Also how can I make this field mandatory and how can I add a tooltip help icon?
    • #106870
      ashley.younguk
      Sorry – the shortcode [wcfm_store_info id=”” data=”store_type”] works fine 🙂 thank you!
      I now just need to know how to make it a required field and also to add a help tooltip 🙂
    • #106872
      ashley.younguk
      Don’t worry I figure it out…
      I needed to add
      'hints' => __( 'Product tags are descriptive labels you can add to your products. Popular search engines can use tags to get information about your store. You can add more than one tag separating them with a comma.', 'wc-frontend-manager' )
      In the array for the help tooltip and
      'required' => 1
      Thanks for your help – you guys rock!! 🙂
