Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › customer invoice problem
- This topic has 16 replies, 4 voices, and was last updated 6 years, 10 months ago by
d-n-13.
- August 25, 2018 at 9:52 am #29687
- August 28, 2018 at 6:03 pm #29995
Invoice properly generating but currency not properly displayed.
You are using Rupee currency, right?
We are looking into this and will resolve very soon.
- August 28, 2018 at 6:28 pm #29996
d-n-13
Same thing, I’m using this Add-On to fix the issue (https://wordpress.org/support/topic/i-have-a-problem-with-language/) it shows currencies and some unsupported languages, but the layout with WCFM is not compatible and it will be messed up
- September 15, 2018 at 11:51 pm #31729
MemberHi @fksujan,
WCFM Ultimate 5.0.6 version has just released and we have added such advanced currency support option.
Kindly update yours and enable this option from WCFM Admin Setting -> Store Invoice
- September 18, 2018 at 5:23 pm #31961
d-n-13
ParticipantI tried WCFM Ultimate 5.0.6 version but Invoices are yet to support my 2nd language.
And WooCommerce PDF Invoices & Packing Slips + mPDF works with my language but layout is not compatible with WCFM.
Possible to add support for my 2nd lang or add compatibility with PDF Invoices & Packing Slips Add-on ?
- September 19, 2018 at 4:44 pm #32016
I have just checked this in your site.
WCFM Invoice “Advanced Character” is ON and your second language is perfectly supporting – https://ibb.co/e7HsXK
What’s the issue you are having, please know me!
- September 19, 2018 at 9:32 pm #32050
d-n-13
“WCFM Invoice “Advanced Character” is ON and your second language is perfectly supporting – https://ibb.co/e7HsXK ”
1- – it is perfectly supporting because i’m using (WooCommerce PDF Invoices & Packing Slips + mPDF) Add-On , but it only perfect in packing slip, other invoices layout is broken.
PDF Invoices Links :
https://www.dropbox.com/s/7izsx43559s709g/packing-slip-6924.pdf?dl=0
https://www.dropbox.com/s/vfproh8furhz7hq/invoice-6924.pdf?dl=0
https://www.dropbox.com/s/ij13k3fmvxyqncx/invoice-53.pdf?dl=0
https://www.dropbox.com/s/7s115dhcg0flgx4/Customer%20Invoice%20from%20vendor.pdf?dl=02- If i disable (WooCommerce PDF Invoices & Packing Slips + mPDF) Add-On then wcfm alone won’t support my language correctly
- September 19, 2018 at 10:26 pm #32055
Can you please disable “mPDF” library and take a look.
- September 20, 2018 at 2:05 pm #32129
d-n-13
“Can you please disable “mPDF” library and take a look.”
removing that mPDF will fix the layout, but language won’t be supported anymore.
Invoice Link : https://www.dropbox.com/s/wkg9nyei5vdeotn/invoice-arabic.pdf?dl=0
Maybe adding compatibility to mPDF layout will fix it ? idk
- September 24, 2018 at 8:00 pm #32444
“Advanced Character” – Is this ON for the site at WCFM Admin Setting -> Store Invoice?
- September 24, 2018 at 8:54 pm #32465
d-n-13
Participant“Advanced Character” – Is this ON for the site at WCFM Admin Setting -> Store Invoice?
Yes
- September 25, 2018 at 9:11 am #32492
Please take a look now, Invoice RTL support added – https://ibb.co/mN67CU
mPDF is required for the purpose.
- September 25, 2018 at 10:21 am #32503
d-n-13
GuestPlease check other invoices, not just packing slip, they’re not working as expected
- September 25, 2018 at 10:51 am #32508
Which Invoice? Store Invoice or Commission Invoice?
Place a new order and take a look.
Store invoice are already generated for old orders so you can’t see changes there.
- September 25, 2018 at 12:19 pm #32516
d-n-13
GuestI just made new order,
please check sale invoice / commission invoice / customer invoice, all of them not appearing correctly.
sale and customer invoices layout in total price not appearing as expected.
commission invoice is messed up.
- September 27, 2018 at 1:40 pm #32666
I have just downloaded this Invoice from you demo site – https://ibb.co/nExLMp
Hope you are testing in this site – https://www.4.wegospace.com/
If in other site then please update WCFM Ultimate to 5.1.1
- September 27, 2018 at 3:38 pm #32703
d-n-13
I have added separate topic for the issue here if you don’t mind : https://wclovers.com/forums/topic/store-invoice-commission-layout-translation-issue/
You can close the topic if @fksujan issue is resolved.
- The topic ‘customer invoice problem’ is closed to new replies.
