Commemorating the Holi Week GOOD FRIDAY SALE - Upto 20% off on all addons.
GRAB NOW!
02Day 02Hrs 16Min 02Sec
Customisation of Add Product Form
Viewing 0 reply threads
    • #133150
      orcansaygili
      Is there any way that I can customize the “Add Product” Forum in a way that I can provide the easiest data entry while they are uploading a product? For example I have added a custom field and made it compulsory to select. However, instead of having it at the bottom as a menu, I would like to have that field at just below the Product Title or “Simple Product” section not as a menu at the down left but as a drop down menu.
      In General, if there is something I can move things around that would be awesome but the mentioned situation above is a bit more urgent.
      Best Regards,
      Orcan
