00Day 15Hr 40Min 30Sec
Customising vendor Product Add screen
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Customising vendor Product Add screen
Viewing 2 reply threads
    • #53322
      hello4
      Hello there,
      Could you kindly help me to get a couple of things done please?
      1) I have 2 product attributes (namely Designer and Size) and I want those to be always ‘Active’, ‘Visible on the product page’ and not visible to vendors
      2) Make only one value can be selected for the Designer attribute
      3) Make all product attribute entry forms always opened (collapsed)
      4) Set ‘Bookable’ and ‘Priority’ values to their defaults (No, 10) and hide those
      5) Automatically copy the Description field content to Short Description field and hide the Short Description field
      I use a customised version of your ‘WCFM Customise Add Products’ plugin and and tried this for the 1st item in my list but it didn’t work:
      add_filter('wcfm_wcbokings_attribute_fields', array( &$this, 'wcfmbi_wcbokings_attribute_fields' ), 50, 2);
      function wcfmbi_wcbokings_attribute_fields($attribute_fields, $product_id)
      		global $WCFM, $WCFMpb;
          	if (isset($attribute_fields['select_attributes_pa_designer_is_active_0'])) {
      			$attribute_fields['select_attributes_pa_designer_is_active_0']['value'] = 'enable';
      			$attribute_fields['select_attributes_pa_designer_is_active_0']['class'] = 'wcfm_custom_hide';
      			$attribute_fields['select_attributes_pa_designer_is_active_0']['label_class'] = 'wcfm_custom_hide';
          return $attribute_fields;
      WooCommerce Frontend Manager – Ultimate – 5.4.0
      WooCommerce Multivendor Marketplace – 2.2.5
      WooCommerce Multivendor Membership – 2.4.1
      WooCommerce Bookings – 1.12.2
      WooCommerce – 3.5.6
      Many thanks in advance.
    • #53539
      Well, such things comes under paid customization.
      If you are interested then may contact us here – https://wclovers.com/woocommerce-multivendor-customization/
    • #53541
      hello4
  • The topic ‘Customising vendor Product Add screen’ is closed to new replies.
