Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Customize 'Orders' Menu
- This topic has 3 replies, 2 voices, and was last updated 6 years, 9 months ago by
- November 6, 2018 at 1:04 pm #35930
acauaferreira
Participanthi, I Would like to remove the ”date” ” address” ”earnings” ”actions”
and ADD ‘Booking start Date’ and if possible ”Total People’Could you help me?
❤Attachments:
You must be logged in to view attached files. - November 6, 2018 at 3:17 pm #35958
You may off course columns from Orders page.
Kindly go to Admin Dashboard -> Orders -> Screen Manager (Check at topbar right -> Monitor icon) -> Disable unnecessary columns (https://ibb.co/duPCoV)
‘Booking start Date’ and if possible ”Total People’ – This are already in Bookings Dashboard
- November 6, 2018 at 5:53 pm #35983
acauaferreira
ParticipantThanks! I never noticed this screen manager.
Yes I need ”Booking start Date’ + ”Total People’ Inside orders, because I will use Just the ORDERS menu.
From Booking menu I will use just the calendar, all other infos there is yet in orders,and don’t make sense access 2 menus to find booking information.So, its possible and viable to add that 2 additional infos to listing orders?
- November 8, 2018 at 8:41 am #36114
Memberhi,
Better i will suggest you to use Booking listing instead orders.
You may add that as separate menu as well.Thank You
- The topic ‘Customize 'Orders' Menu’ is closed to new replies.
