Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Customize Packing Slip
- This topic has 7 replies, 2 voices, and was last updated 6 years, 9 months ago by
- November 30, 2018 at 7:19 am #38701
andreasenglowski
i did create my own template for packing slip (where i did add a few custom fields). But the template is only used when creating pdf via admin backend, if created by vendor via vendor dashboard a different template is used. Can you tell me where to edit your template file so i can add my fields to vendor packing slip, too?
Many thanks in advance,
Andi - November 30, 2018 at 8:19 am #38702
WCFM use a separate template for all such purposes as those required multi-vendor support.
Well, you have to override this template for the purpose -> “wc-frontend-manager-ultimate\views\vendor_invoice\packing-slip.php” under your child theme/wcfm/vendor_invoice\”
- November 30, 2018 at 10:15 am #38712
andreasenglowski
ParticipantThis reply has been marked as private. - November 30, 2018 at 1:48 pm #38728
Those will not work here.
Placeholder requires replacement, but that is not written for packing-slip.
For this you have to edit core files.
Or, use store invoice as packing slip also.
- December 3, 2018 at 9:54 am #38910
andreasenglowski
ParticipantOkay many thanks, thats a great idea, but how do i use store invoice as packing slip also?
- December 3, 2018 at 10:19 am #38911
Vendors are allowed to download Store Invoice for their orders from their orders dashboard.
Just instruct them to use that for Packing Slip as well.
And set OFF this capability then there will be no more additional Packing Slip download option -> https://ibb.co/ynDGFS2
- December 3, 2018 at 10:52 am #38914
andreasenglowski
ParticipantOh okay so but then vendors won’t be able to download a store invoice anymore, right? I mean the store invoice will be my custom packing slip then and theres no more real invoice.
All the best,
Andi - December 3, 2018 at 4:08 pm #38940
Sorry, I can’t get you point.
I suggested you to ->
1. Disable packing Slip Capability -> https://ibb.co/ynDGFS2
2. Ask your vendors to use Store Invoice as packing slipThank You
- The topic ‘Customize Packing Slip’ is closed to new replies.
