Dashboard columns not aligning to hide/unhide settings
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Dashboard columns not aligning to hide/unhide settings
Viewing 8 reply threads
    • #36824
      gail
      This has just happened as it was correct – the columns in both admin and store vendor views are not aligned to the display settings. I have marked Billing Address as hidden on both accounts but is showing on both dashboards.
      Also UNPAID has just appeared underneath every price in the Store Vendor view, the orders are all paid. How can this be removed.
    • #36888
      Kindly update your WCFM Ultimate to latest version – 5.1.6
    • #36916
      gail
      I have updated and refreshed but nothing has changed.
    • #36946
      Do you have caching plugin or other type of caching system?
      If so, then please refresh those caches once and take a look.
    • #37054
      gail
      We do not have caching plugins, have installed one and cleared cache on WordPress and on server, and in the browser. This has not fixed the issue, the wrong columns are still showing on the dashboard.
    • #37087
      Kindly update your WCFM to 5.1.9 and WCFM Ultimate to 5.1.7
    • #37143
      gail
      WCFM is updated to 5.1.9 and WCFM Ultimate is showing as up to date at 5.1.6 – how can I update if it is not showing as out of date in WordPress?
    • #37146
      gail
      OK I updated the plugin manually via cPanel and it has fixed the problem. For anyone else with the same issue I had to reset column visibility setting after updating the plugin to 5.1.7.
    • #37173
      That’s great and thanks for update here 🙂
  • The topic ‘Dashboard columns not aligning to hide/unhide settings’ is closed to new replies.
