Best Multi Vendor Marketplace Plugin for WordPress › Forums › Product Vendors › Dashboard content not Displaying.
- This topic has 2 replies, 2 voices, and was last updated 5 years, 8 months ago by
nathantivon.
- June 8, 2020 at 2:24 am #139385
nathantivon
ParticipantAll I have is the Dashboard menu and sub-menu options. But when you click on a menu option, the content to the right does not show.
Vendors as well. It has worked fine previously. Please see the attachments.Nothing in the error logs, everything updated.
Thank youAttachments:
You must be logged in to view attached files. - June 9, 2020 at 11:50 am #139808
Sarmistha Chakraborty
It seems like this is happening due to some plugin conflict. Kindly disable all other plugins except WooCommerce and WCFM plugins and activate WordPress default theme, then check again.( remove custom codes if you have added any)
- June 10, 2020 at 11:52 am #140173
nathantivon
ParticipantThank you. It after trying your suggestion it appears to be the theme. It is a pretty popular theme, Electro by Madras Themes (https://madrasthemes.com/).
Are you familiar with that theme? and is there any other option than switching themes?
thanks again
