Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Dashboard settings
- This topic has 2 replies, 1 voice, and was last updated 9 years, 1 month ago by
WCfM Forum.
- October 4, 2017 at 9:38 am #13896
Plamen
I really like your solution and I have the following questions:
1. If I understand correctly, the plugin follows this scenario: the vendors are selling goods on the website, the owner is receiving the payments, he keeps a % commission for himself and he passes the balance on to the vendors.
2. In my case the vendors will receive their payments and I only want to charge them commission on each sale. Therefore I would like to make some amendments on the dashboard as it is a bit confusing the way it is: the home page of the dashboard is currently showing 4 items: net sales (after the website owner’s commission), commission in last 7 days (which is zero for the vendors and the % for the website owner), items and orders.What I would like to amend is: item 1 to show the gross amount of the sales (including the commission), item 2 to show the commission that the vendor owes the website owner, items 3 and 4 are OK as they don’t affect the changes in the scenario (as far as I can see). The dashboard of the website owner is not very important as it will not be available for users. I just need to be able to create reports with the correct commission amounts for each vendor, but I assume this is already available.
Many thanks in advance for your support!
Best regards,
- October 4, 2017 at 9:46 am #13897
Plamen
GuestI am sorry, the question was about WCFM, so could you please move this topic to the correct section.
I again apologies for the inconvenience.
- October 4, 2017 at 10:26 am #13899
WCfM Forum
That will be not an issue, can you please confirm one thing – are you using WC Marketplace as Vendor Plugin for your site?
As far I understand, you have set Admin Fees instead of Vendor Commission, right!!
I just want to confirm you that, what you want is absolutely possible. But by default there is no such Settings, a small tweaks require to achieve this.
If I send you a custom code for this will you able to integrate through child theme? Or I should create a separate Custom Plugin for this, then you have to just install that!!
Please know me which will be better for you.
- The topic ‘Dashboard settings’ is closed to new replies.
