Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › DataTables warning
- This topic has 14 replies, 4 voices, and was last updated 7 years, 10 months ago by
- September 18, 2017 at 10:13 am #13445
Hello!
GuestHi!
After last updates I have got DataTables warnings- invalid JSON response. There in message is following link; https://datatables.net/manual/tech-notes/1
But I donยดt know how fix this issue? Could you tell me what I should to do? Thanks. - September 18, 2017 at 10:38 am #13447
Shhiv Narayan
Really sorry for the inconveniences.
For which dashboard you are getting this error?
Are you using any caching Plugin?
Kindly clear your browser cache and check once.Thank You
- September 18, 2017 at 11:03 am #13450
Hello!
ParticipantHi!
This is warnings:
DataTables warning: table id=wcfm-coupons – Invalid JSON response. For more information about this error, please see http://datatables.net/tn/1DataTables warning: table id=wcfm-orders – Invalid JSON response. For more information about this error, please see http://datatables.net/tn/1
I have LiteSpeed Cache, I tried clear, but did not help ๐
- September 18, 2017 at 11:42 am #13460
Shhiv Narayan
Can you please confirm one more thing –
WCfM and WCfM Ultimate both are at latest version 3.1.0 ?
Actually there has no issue in core plugin, you may check any of our demos.
So I am trying to understand what happened to your system.Thank You
- September 18, 2017 at 11:57 am #13461
Hello!
ParticipantHi!
Yes, both are latest versions. Maybe some else plugin causes that error, I will test it next… But while it, I would like suggest you some plugins for integrate to your plugin, what you say;
*YITH WooCommerce Advanced Reviews Premium = Vendor can answer to reviews from own dashboard (not delete or edit ๐ )
*YITH WooCommerce Dynamic Pricing and Discounts Premium
*YITH Woocommerce Request A Quote Premium = Vendor can see and reply to requests from dashboard.
*YITH Live Chat Premium =Vendors can use chat on dashboard.
*WPML โ Admin can translate plugin using WPML and vendors can translate their products (just only translate, not duplicate) to languages which admin has set.
Thanks ๐
- September 18, 2017 at 12:16 pm #13462
Shhiv Narayan
Yeah sure, we will look in to this list and inform you with WCfM future road map.
If you are comfortable enough to share your site access with us then our team will debug the issue for you.
- September 18, 2017 at 12:34 pm #13465
Hello!
ParticipantHi!
Okay, but I think I found plugin which causes this issue. Plugin is Ultimate Member – Verified Users. Should I contact them if I wish use that plugin or can you fix it on your plugin? I don`t have idea is the problem in your plugin or their? ๐
- September 18, 2017 at 4:54 pm #13466
Hello!
ParticipantHi again!
By the way, I saw small bug. If vendor changes his/her store name from settings page, vendors name on product “Vendor”-tab does not update.
- September 18, 2017 at 5:32 pm #13471
Which vendor plugin you are using in?
Without checking the actual error I can’t say anything, but I understood there has some conflict.
You may ask that plugin author once, I think they have called some admin site function from frontend so such error arises.Thank You
- September 18, 2017 at 6:36 pm #13472
Hello!
ParticipantHi!
I use Wc-marketplace-plugin. Okay, I will ask it from that other plugin author. Thanks
- September 19, 2017 at 5:15 am #13499
MemberGreat, Thank You
- September 24, 2017 at 7:42 am #13643
Hello!
GuestHi!
This issue is resolved ๐
- September 24, 2017 at 9:18 am #13644
WCfM Forum
GuestWow …. Great to know that it’s working fine for you now.
Are you comfortable enough to share the reason of this, it will also helpful for others as well.
- September 25, 2017 at 10:37 am #13678
Hello!
GuestThis reply has been marked as private. - September 26, 2017 at 5:45 am #13690
MemberAhh.. Thanks for the information.
I am closing this thread for now.
- The topic ‘DataTables warning’ is closed to new replies.
