Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Bookings › Date format format for bookable product
- This topic has 9 replies, 3 voices, and was last updated 5 years, 6 months ago by
- January 13, 2020 at 2:08 pm #101872
fred
ParticipantHi Admin,
I would need some help about date format.
I am currently using WooCommerce booking along with WCFM Ultimate + Marketplace
The date formats for bookable products have the following format : MM / DD / YYYY
How can I modify the front-end to display a french format : DD / MM / YYYY
Here is an example of page where the dates are displayed : https://www.booking-gaysejour.com/chambre/chambre-confort-etage/
Thanks in advance for your help
- January 30, 2020 at 7:11 pm #104700
Unfortunately, WC Bookings does not support such custom date format. If you change the format, it will not work.
Thanks - February 20, 2020 at 1:09 am #107926
perets.studio
ParticipantThis reply has been marked as private. - February 20, 2020 at 5:33 pm #108042
KeymasterHello,
To do calculation based on nights instead of day, you will require https://woocommerce.com/products/woocommerce-accommodation-bookings/ this plugin in addition to WooCommerce Bookings.
So, I guess you want to set a minimum price say $300 as the rent of the room, this is the amount if a single person or a couple have to pay for a night. Now for each extra person it will add $150 with the total. Am I right?
Let me know. - February 20, 2020 at 7:03 pm #108055
perets.studio
ParticipantHi I have the extension worker by night, I want to do that, for example those available in more than 3 nights price per night will be lower
- February 25, 2020 at 5:45 pm #108740
Please refer to this link https://docs.woocommerce.com/document/change-price-booking-based-on-duration-stay/
Thanks! - February 26, 2020 at 12:42 am #108814
perets.studio
Participanthi yes this i know i want to know if can be somting like that with https://woocommerce.com/products/woocommerce-accommodation-bookings/ becucse i want per night
thanks
- February 26, 2020 at 12:04 pm #108862
KeymasterHello,
WooCommerce Accommodation Bookings is simply an extension of WooCommerce Bookings plugin. So all the booking settings remains the same.
Thanks! - February 26, 2020 at 8:27 pm #108921
perets.studio
ParticipantHey please try because it is different products if i want overnight i have to use different product from booking product then i don’t have the option of making a discount by cube etc.
- February 27, 2020 at 3:34 pm #109025
KeymasterHello,
Didn’t get your last reply. Please tell me in details how you want to set your accommodation products? Or send me your product link and tell me what different behavior you want to achieve from it?
