Deadlock found when trying to get lock
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Deadlock found when trying to get lock
Viewing 3 reply threads
    • #90548
      thiemann.k
      Hey Community,
      I have a problem with my database again.
      Can you help me with this?
      [03-Nov-2019 23:15:25 UTC] WordPress-Datenbank-Fehler Deadlock found when trying to get lock; try restarting transaction für Abfrage DELETE FROMwp_optionsWHEREoption_name` = ‘wcfm_updated_end_point_wc_listings’ von require(‘wp-blog-header.php’), require_once(‘wp-load.php’), require_once(‘wp-config.php’), require_once(‘wp-settings.php’), do_action(‘init’), WP_Hook->do_action, WP_Hook->apply_filters, WCFM_Customer->customers_wcfm_init, WCFM_Query->init_query_vars, apply_filters(‘wcfm_query_vars’), WP_Hook->apply_filters, WCFM_Integrations->wcfm_thirdparty_query_vars, delete_option, QM_DB->query
      [03-Nov-2019 23:15:25 UTC] WordPress-Datenbank-Fehler Deadlock found when trying to get lock; try restarting transaction für Abfrage DELETE FROM wp_options WHERE option_name = ‘wcfm_updated_end_point_wc_listings’ von require(‘wp-blog-header.php’), require_once(‘wp-load.php’), require_once(‘wp-config.php’), require_once(‘wp-settings.php’), do_action(‘init’), WP_Hook->do_action, WP_Hook->apply_filters, WCFM_Vendor_Support->vendors_wcfm_init, WCFM_Query->init_query_vars, apply_filters(‘wcfm_query_vars’), WP_Hook->apply_filters, WCFM_Integrations->wcfm_thirdparty_query_vars, delete_option, QM_DB->query
      [04-Nov-2019 01:53:59 UTC] WordPress-Datenbank-Fehler Deadlock found when trying to get lock; try restarting transaction für Abfrage DELETE FROM wp_options WHERE option_name = ‘wcfm_updated_end_point_wc_listings’ von require_once(‘wp-load.php’), require_once(‘wp-config.php’), require_once(‘wp-settings.php’), do_action(‘init’), WP_Hook->do_action, WP_Hook->apply_filters, WCFM_Customer->customers_wcfm_init, WCFM_Query->init_query_vars, apply_filters(‘wcfm_query_vars’), WP_Hook->apply_filters, WCFM_Integrations->wcfm_thirdparty_query_vars, delete_option
    • #91127
      What is your WC Frontend Manager plugin’s version?
    • #91182
      thiemann.k
      Hey, tanks for your answer.
      I take an screenshot from our installed plugins.
      https://ibb.co/XzNyLmJ
      I do not understand myself what’s going on at the moment
      Thanks, Karsten
    • #91836
      Well, plugins are already at latest version.
      DO you have talk to hosting support for this yet? If not, please talk to them once!
  • The topic ‘Deadlock found when trying to get lock’ is closed to new replies.
