Default tax_status and tax_class setting
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Default tax_status and tax_class setting
Viewing 7 reply threads
    • #39589
      Jay
      I disabled tax settings from Vendor’s capability.
      When Admin opens product manager after vendor submitting a product for review, it’s showing tax_status=”None” and tax_class=”Standard” by default.
      I don’t have such issue when I add product in Admin’s account directly.
      Is there code snippet I could use to make tax_status=”taxable” by default?
      Something like:
      $array[‘tax_status’][‘value’] = ‘taxable’;
      $array[‘tax_class’][‘value’] = ‘standard’;
      Jay
    • #39595
      “I disabled tax settings from Vendor’s capability.”
      – As tax capability disabled for vendors so their added products generated with Tax status “None”.
      What’s wrong in this?
    • #39657
      Jay
      I am disabling Tax for vendors, because every product they post should be ‘taxable’.
      Jay
    • #39658
      But unfortunately, if you disable anything then it will off by default.
      Better, you keep that enable for your vendors and instruct them not to OFF tax for products.
    • #39661
      Jay
      Then is there way to hide(wcfm_custom_hide) tax tab in the product manage tab via functions? Or hiding through CSS is only the option?
    • #39664
      OK< use this code ->
      add_filter( 'wcfm_pm_block_class_tax', function( $classes ) {
      	return '';
      But keep ON Tax capability.
    • #39666
      Jay
      Thanks for your help.
      It works!
      ~Jay
    • #39667
      Great … you are welcome 🙂
  • The topic ‘Default tax_status and tax_class setting’ is closed to new replies.
