Delivery location not showing in checkout after updated lates version -URGENT!!
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Delivery location not showing in checkout after updated lates version -URGENT!!
Viewing 5 reply threads
    • #130378
      djks74
      Dear WCFM,
      please fix delivery location (checkout map) not showing in checkout after updating all latest version of WCFM.
    • #130379
      ciccupio97
      Follow
    • #130406
      djks74
      I need to downgrade first for wcfm marketplace then its back showing for the map.
      please fix it. Thanks.
    • #132209
      djks74
      Maybe you guys not notice, it not showing when I force to billing address.
      thats why its still showing when we set default or has shipping address on woocomemrce.
      • #138896
        sudesna401
        you are absolutely right. to fix the map issue you must use default to the customer billing address in the woocommerce setting. If you use force to billing it will not work. see attachment.
    • #138898
      sudesna401
      Hey, to fix the map issue you must use default to the customer billing address in the woocommerce setting. If you use force to billing it will not work. see attachment.
    • #148361
      maxzu_11
      Se puede configurar el mapa que esta en el checkout para dar clic dentro de el(marcar la ubicacion) y automáticamente salga la dirección de envío de delivery?
  • The topic ‘Delivery location not showing in checkout after updated lates version -URGENT!!’ is closed to new replies.
