Diwali
00Day 21Hr 09Min 17Sec
Diwali
Diable downloadable products and set virtual as default
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Diable downloadable products and set virtual as default
Viewing 1 reply thread
    • #121153
      ZK
      Hi
      Is there a way to disable “Downloadable” products and set “Virtual” products as default. I have been able to do this in woocommerce but seems it doesn’t effect the WCMP plugin.
      b/w
    • #121268
      Keymaster
      Thanks for getting in touch with us.
      To disable “Downloadable” products go to Capabilities menu from your WCFM Dashboard. From there uncheck “Downloadable” under Types. Refer to this- https://imgur.com/hn4eenB
      Now to set Virtual as default use the following snippt-
      function wcfm_product_manage_fields_general_custom_virtual( $general_fields, $product_id ) {
      	if( isset( $general_fields['is_virtual'] ) && ! $product_id ) {
      		$general_fields['is_virtual']['dfvalue'] = 'enable';
      	return $general_fields;
      add_filter( 'wcfm_product_manage_fields_general', 'wcfm_product_manage_fields_general_custom_virtual', 10, 2 );
      Let me know how it goes.
  • The topic ‘Diable downloadable products and set virtual as default’ is closed to new replies.
