Disable store location map
Viewing 4 reply threads
    • #109248
      marcinzywy
      Hello WC Lovers,
      I would like to completely disable store location map.
      I can see there is a store location map setting in the store setup wizard as well as in vendor dashboard settings tab, so I would like to hide both.
      Thank you for your help!
    • #109536
      Make the “Google Map API Key” blank in admin WCFM store dashboard settings. Please find the attachment.
    • #109705
      marcinzywy
      Thank you Sarmistha! Your tip is very helpful.
    • #120919
      Henriette
      I was searching for this too and it works indeed.
      But Vendor still has an option in his dashboard “Hide Map from Store”.
      How can I remove this?
      • #121415
        To remove “Hide Map from Store” add this code in your theme’s functions.php
        add_filter('wcfm_marketplace_settings_fields_visibility', 'wcfm_marketplace_settings_fields_visibility2104', 50, 2 );
        function wcfm_marketplace_settings_fields_visibility2104($general_fields,$vendor_id) {
        	unset($general_fields['store_hide_map']);
        	return $general_fields;
    • #121632
      Henriette
      That worked.
      Thank you very much.
  • The topic ‘Disable store location map’ is closed to new replies.
