Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Disabling vendors won't let their products go to Draft + wpml error msg
- This topic has 5 replies, 2 voices, and was last updated 7 years ago by
- August 20, 2018 at 12:17 am #28920
d-n-13
1- When canceling a membership then vendor will be disabled and his products will go to Draft as expected. But when disabling vendor directly before canceling membership then his products will stay online, same for wpml translated products.
2- I tried to workaround this issue by canceling membership, but it turned out free memberships cannot be canceled. not so important if I can disable vendor directly.
3- Admin Dashboard => Vendors => VendorX = > Membership = wpml error only appears for paid memberships, I pointed this error last month but it wasn’t fixed, and I don’t think it is causing any issues in wcfm functionality (Check screenshots = free membership : https://imgur.com/ftaJ7cP – Paid membership : https://imgur.com/yQjNxsh)
- August 20, 2018 at 4:43 am #28938
– WCFM Membership disable vendor has no such rule to change his products into draft. We will add prohibition for this in next update.2- I tried to workaround this issue by canceling membership, but it turned out free memberships cannot be canceled. not so important if I can disable vendor directly.
– Yeah right, when membership cancelled then basic membership auto-assign to the vendor3- Admin Dashboard => Vendors => VendorX = > Membership = wpml error only appears for paid memberships, I pointed this error last month but it wasn’t fixed, and I don’t think it is causing any issues in wcfm functionality (Check screenshots = free membership : https://imgur.com/ftaJ7cP – Paid membership : https://imgur.com/yQjNxsh)
– I have resolved this in your dtagingBetween, can you share FTP for that staging? By mistake I added a “die” and now site can not be reached!
Sorry, for the trouble.Thank You
- August 20, 2018 at 10:46 am #28959
d-n-13
ParticipantThis reply has been marked as private. - September 2, 2018 at 5:30 am #30459
MemberThis has been resolved in WCFM Membership latest update.
- September 2, 2018 at 7:11 am #30468
d-n-13
I saw the update notes, it is great that you guys don’t forget about old Topics !
Thank You.
- September 2, 2018 at 10:13 am #30510
MemberWe never forget anything 😀
- The topic ‘Disabling vendors won't let their products go to Draft + wpml error msg’ is closed to new replies.
