Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Discount on commission
- This topic has 3 replies, 2 voices, and was last updated 5 years, 9 months ago by
- November 19, 2019 at 2:55 pm #92939
verghetti76
ParticipantHi.
I have sellers divided by groups. According to the subscriptions I organized, I would need each group to have a special discount on the standard commission. How can this be done? I have seen that in each group a different commission can be set, but it affects all the categories (and in my case the categories have different commissions). It would be perfect if, within the groups, a percentage of commission could be entered for each category. Do you have any suggestions? Thanks - November 23, 2019 at 10:37 am #93547
– Well, if you have set category wise commission then that will be applicable, not membership/group wise commissions.
DO you want to set different category commission based on groups?
- November 23, 2019 at 3:09 pm #93609
verghetti76
ParticipantDO you want to set different category commission based on groups?
Yes, exactly! But also with the plugin “Membership” It seems impossible…
- November 26, 2019 at 2:54 pm #94029
MemberYeah, right now this is not supported!
- The topic ‘Discount on commission’ is closed to new replies.
