Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Display Issues with Store List (wcfm_stores)
- This topic has 7 replies, 2 voices, and was last updated 6 years ago by
- July 31, 2019 at 1:29 pm #74607
shitT
ParticipantHello
I created a store list with wcfm_stores widget. Basically an interesting feature, but unfortunately I have the following issues / shortcomings:
1. Order button not readable (white on white – see https://ibb.co/1rLRdJG). How can I change the background and/or font color of this button? (Doesn’t seem to get targeted with .orderby css…)
2. Email in Store Card is suboptimal. I want to hide this and have the user contact the store over the inquiry button instead. Further, I would like to show the store adress instead. How can I do this? (see desired result here: https://ibb.co/WPTwNzG)
3. Store Card “classic” theme: Depending on the banner, the white font is difficult to read. Is there a way to set the background of the store to a color (e.g green) instead of the banner image?
4. Map: The pegman is not showing (see https://ibb.co/ZLG5YWs). How can I fix this?
5. Map: The grey colour of the locator is to dark for the satellite view (see https://ibb.co/rHkSqFm). How can I change the color of the locator?
Your help would be very much appreciated!
Kind Regards
Gilbert - August 3, 2019 at 9:13 am #75003
– Possibly it’s due to theme CSS. Add this CSS to your site –
#wcfmmp_store_orderby {color:#111111;}
– Disable “Show Email” option at Capability setting
– Please change this color from WCFM Admin Setting -> Store Style – https://ibb.co/Z8SrtJH
– This is a icon from Google Map – https://ibb.co/wwR9CNg
I am not sure why it’s visible in your map.5. Map: The grey colour of the locator is to dark for the satellite view (see https://ibb.co/rHkSqFm). How can I change the color of the locator?
– It’s possible to use customize icon for the purpose. Please share your icon URL with me, I will help you to setup this.
- August 3, 2019 at 1:57 pm #75037
shitT
Thanks for your answers! Already helped me a lot.
I still have following questions. Could you please help me with those?
– Is it possible to show the store address in the store card?
– Is it possible to use the same background color for all cards instead of the store banner?
– How can I eliminate the frame (box/shadow) around the widget?Greatly appreciate your help!
GilbertPS:
– The pegman issue is solved (4). Was a css problem. Added .gm-style img {max-width: none}
– Got a workaround for the map issue (5). Simply disabled the satellite view in css with .gm-style-mtc {display: none;} - August 4, 2019 at 9:42 am #75164
– Use this CSS for the purpose –
#wcfmmp-stores-wrap ul.wcfmmp-store-wrap li .store-data p.store-address{display"block!important;}
– Do you want to disable store list banner from here and want to show a static color? Please know me that color, I will give you CSS for the purpose.
– Which widget frame? Please show me screenshot for this.
- August 4, 2019 at 3:30 pm #75186
shitT
Thanks a lot for your fast answer. My answers below after ->:
#wcfmmp-stores-wrap ul.wcfmmp-store-wrap li .store-data p.store-address{display”block!important;}
-> There is still a small issue with this code: The address information is in the page, but it is not displayed (see https://ibb.co/VwSB0cP). Something missing?
-> Yes, exactly. The color would be #e6cc66.
-> Screenshot: https://ibb.co/PNS19mg
Thanks a lot for your help!
- August 5, 2019 at 3:54 pm #75359
Here is your total CSS –
#wcfmmp-stores-lists{box-shadow:none!important;} #wcfmmp-stores-wrap ul.wcfmmp-store-wrap li .store-content{background-color:#e6cc66!important;} #wcfmmp-stores-wrap ul.wcfmmp-store-wrap li .store-content .store-info{background:transparent!important;} #wcfmmp-stores-wrap ul.wcfmmp-store-wrap li .store-data p.store-address{display:block!important;}
- August 6, 2019 at 9:30 am #75444
shitT
ParticipantWorks perfectly. Thanks a lot!
- August 9, 2019 at 1:11 pm #75949
MemberYou are welcome 🙂
- The topic ‘Display Issues with Store List (wcfm_stores)’ is closed to new replies.
